how can i display the data using graph widget on blynk??? help me please, im beginner… im appreciate ur help…tq all
below are my ino.
#include <Filters.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
const int LED =25;
const int Relay =33;
float testFrequency = 60; // test signal frequency (Hz)
float windowLength = 20.0/testFrequency; // how long to average the signal, for statistist
int sensorValue = 0;
float intercept = -0.1129; // to be adjusted based on calibration testing
float slope = 0.0065; // to be adjusted based on calibration testing
float current_amps; // estimated actual current in amps
unsigned long printPeriod = 1000; // in milliseconds
// Track time in milliseconds since last reading
unsigned long previousMicros = 0;
Serial.begin( 57600 ); // start the serial port
pinMode(Relay, OUTPUT);
pinMode(LED,OUTPUT);
RunningStatistics inputStats; // create statistics to look at the raw test signal
inputStats.setWindowSecs( windowLength );
while( true ) {
sensorValue = analogRead(A0); // read the analog in value:
inputStats.input(sensorValue); // log to Stats function
if((unsigned long)(millis() - previousMicros) >= printPeriod) {
previousMicros = millis(); // update time
// display current values to the screen
Serial.print( "\n" );
// output sigma or variation values associated with the inputValue itsel
Serial.print( "\tsigma: " );
Serial.print( inputStats.sigma() );
// convert signal sigma value to current in amps
current_amps = intercept + slope * inputStats.sigma();
Serial.print( "\tamps: " );
Serial.print( current_amps );
if (current_amps >= 20)
digitalWrite(LED, LOW);
digitalWrite(Relay, HIGH);
Serial.print("fault occur");
delay(500);
delay(500);
digitalWrite(LED, HIGH);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
delay(500);
digitalWrite(Relay, LOW);
delay(100);
VERY IMPORTANT: You can’t send sensor data in your
gazillion number of times. Which means that Blynk Cloud will be flooded with gazillion messages from your hardware.
︎ cuts your connection. Sorry…
Flash the code to your hardware;
