Good Day!
I am working on a small project with a D1 mini and Blynk Edgent. I am trying to save power as much as possible and have been trying to remove the LED strobe effect in the Blynk Edgent Sketch, but when I do so, I keep getting an error saying " was not declared in this scope",etc.
Is there an easy way to do this without going through each β.hβ Tab, removing the LED bits?
I really want to avoid removing the LED physically as this project isnt a long term one.
Thanks in advance!
Look in Indicator.h and work out what pulses the LED when itβs in normal run mode, and change the code.
However, Iβd keep the rapid pulsing when in provisioning mode if I were you.
I commented out β//analogWrite(BOARD_LED_PIN, TO_PWM(255 - color));β , β//analogWrite(BOARD_LED_PIN, TO_PWM(color));β" and β//pinMode(BOARD_LED_PIN, OUTPUT);β
And the LED no longer functions which is what I want.
Thank you
