Hi, I would like to be able to disable encryption or SSL altogether between the app and the local server preferably using the server.properties (that is, without having to change the source code of the local server). This is for educational purposes to analyze the messages exchanged between the app and the local server.
How to disable encryption on the local server to the app side connection using the server.properties
This issue has been resolved.
Hi Emil,
I’m afraid I’ve been out of the loop with Blynk for quite a while so I’m glad you solved your problem.
Regards
