Hello Everyone can somebody help me to create the URL OF blynk api for IFTTT Google assistance applet.
#include <ESP8266WiFi.h> // Header file for Wifi Module
#include <BlynkSimpleEsp8266.h> // header file for blynk
#include <RBDdimmer.h> // header file for robodyn dimmer
char auth[] = ""; // blynk auth key
char ssid[] = "Yogendra"; // Wifi Name
char pass[] = "Jamsariya"; // Wifi Password
#define outputPin D2 // PWM pin for dimmer
#define zerocross D5 // for boards with CHANGEBLE input pins
dimmerLamp dimmer(outputPin, zerocross); //initialase port for dimmer for ESP8266, ESP32, Arduino due boards
int outVal = 0; // Intialisation value for dimmer
int dim_val; // dimmer value to dim the appliance
Serial.begin(9600); // begin serial communication
dimmer.begin(NORMAL_MODE, ON); //dimmer initialisation: name.begin(MODE, STATE)
Blynk.begin(auth, ssid, pass); // begin blynk server
Blynk.run(); // Run blynk server
BLYNK_WRITE(V0) { // Set to your virtual pin
outVal = param.asInt(); // Get State of Virtual Button
dim_val = map(outVal, 0, 1023, 0, 100); // mapped the value for dimmer
dimmer.setPower(dim_val); // Set dimmer power
Blynk.virtualWrite(V1, dim_val); //sending to Blynk
