How To Control Servo With Timer Blynk
i’m making automatic feed for cats using nodemcu and servo, using blynk timer. but when the timer is running, the servo does not move. what is there anything missing with this program, because I am just learning
i am using the old version of blynk app. thanks in advance
#define BLYNK_AUTH_TOKEN "abE-9rDY3Yd1tP3YjptNucxPsLk5jVkT"
//Token dan SSID WiFi
char auth[] = "abE-9rDY3Yd1tP3YjptNucxPsLk5jVkT";
char ssid[] = "Redmi Note 9";
char pass[] = "12345678901";
//BLYNK
//RTC
#include <TimeLib.h>
#include <WidgetRTC.h>
WidgetRTC rtc;
//SERVO
#include <Servo.h>
Servo servo;
int servo = 12;
/* 2- Display refresh*/
unsigned long startMillis;
unsigned long currentMillis;
const unsigned long period = 1000;
BLYNK_CONNECTED()
{ rtc.begin(); }
/* 0 - General */
pinMode(2,OUTPUT);
/* 1- Blynk Server and Wifi Connection */
setSyncInterval(1);
Blynk.begin(auth,ssid,pass, "iot.serangkota.go.id", 8080);
while (Blynk.connect() == false ) {}
setSyncInterval(10*60);
startMillis = millis();
//SERVO
servo.attach(D6);
servo.write(0);
 BLYNK_WRITE(V4){
 servo.write(param.asInt());
if (param.asInt()){
    digitalWrite(12, HIGH);
    Blynk.virtualWrite(V12,255);
    Blynk.notify("Pakan diberikan");
    digitalWrite(12, LOW);
    Blynk.virtualWrite(V12,0);
    Blynk.notify("pemberian pakan selesai");
 BLYNK_WRITE(V5){
if (param.asInt()){
 BLYNK_WRITE(V6){
if (param.asInt()){
void loop(){
currentMillis = millis();
if(currentMillis - startMillis > period)
String currentDate = String(day()) + "/" + month() + "/" + year();
Serial.print(currentTime);
Serial.print(" ");
Serial.print(currentDate);
Serial.println();
Blynk.virtualWrite(V1, currentTime);
Blynk.virtualWrite(V2, currentDate);
int getSecond = second();
if (getSecond > 30)
{ digitalWrite(2,HIGH);}                                                      /* Turn OFF the LED if seconds count is more than 30 */
if (getSecond < 30)
{ digitalWrite(2,LOW); }                                                      /* Turn ON the LED if the seconds count is less than 30 */
startMillis = millis();                                                       /* Reset time for the next counting cycle */
What is this server that you’re using?
It looks like some sort if “pirate” legacy cloud server, is that correct?
Since the old blynk can’t be used anymore, my friend said to use that server
This is a support forum for people who use the Blynk cloud servers or their own local servers.
I’d suggest that you ask your friend for support, or upgrade to Blynk IoT.
