Hi all I want Control servo with button This project can you all help me thanks you all.
For sure, look up the Button in the docs and read all the servo posts on this site.
i don’t know control servo by button
i control it slide same.
So… look up Slider in the docs and read all the servo posts on this site.
https://community.blynk.cc/search?q=control%20servo%20with%20slider
plese you printscreen app blynk button preview
I don’t know what you are asking.
If you already know how to control a servo with a Slider Widget, then you should also understand how to get some limited control from a Button Widget.
E.g. setting a Button’s MIN/MAX at 0 and 180 respectively, and linking it to a Virtual Pin and BLYNK_WRITE()
routine, set for servo control, means that Button OFF moves servo to 0 position, Button ON moves servo to 180 position… simple… just experiment and learn
And don’t forget to do some searching for ideas and code that has already been posted…
i’am don’t use buttom naver
you have a code buttom servo .
now use control servo slider
this my code
char auth[] = "YOUR_AUTH_ID";
char ssid[] = "WIFI_SSID";
char pass[] = "WIFI_PASSWORD";
i’m not control via switch help me…
If you want to use a simple button, then you need to use virtual pins, a servo library and some basic code.
https://www.arduino.cc/en/Reference/Servo
http://docs.blynk.cc/#blynk-firmware-virtual-pins-control-blynk_writevpin
https://examples.blynk.cc/?board=ESP8266&shield=ESP8266%20WiFi&example=GettingStarted%2FVirtualPinRead (Use Button Widget instead of slider).
BLYNK_WRITE(V0) // This function gets called everytime the Virtual Button on V0 changes state
int value = param.asInt(); // Get value of button as integer
// Place servo control code here based on value data.
you have code control 1 servo with switch ?
I have code to do lots of things… and I learned how to write them much the same way I am trying to assist you in learning.
Ok . i wait for learning , i’m rookie arduino and C++ I’am age13old ,i want to learn arduino and C++ for study thx.
what to do next,this my code
#include <Servo.h>
Servo myservo;
int button;
int pos;
char auth[] = "authtoken";
Blynk.begin(auth, "ssid", "pass");
myservo.attach(5); // D1 physical pin
BLYNK_WRITE(V0) {
button = param.asInt();
BLYNK_WRITE(V1) {
pos = param.asInt();
if ( button == 1 ) {
myservo.write(pos);
myservo.write(10);
For starters… take this OUT of the main loop and put it in one of the proper BLYNK_WRITE()
functions where it will do it’s job.
i.e
BLYNK_WRITE(V0) { // This function gets called every state change of the Button Widget
button = param.asInt(); // This assigns the Button state to a variable
if ( button == 1 ) { // This checks the value of the variable and if equals 1, does something like...
myservo.write(pos); // ... move the servo to position based on another variable
myservo.write(10); // If variable doesn't equal 1 then set servo to this default position
use code where
if ( button == 1 ) { // This checks the value of the variable and if equals 1, does something like…
myservo.write(pos); // … move the servo to position based on another variable
myservo.write(10); // If variable doesn’t equal 1 then set servo to this default position
I just showed you… I “moved” it into your pre-existing BLYNK_WRITE(V0)
function… and I commented it so that you can see how the whole function works.
