I assumed I would find examples of how to control Philips Hue lights directly from the blynk app, but unfortunately I haven’t. There is a reference to Philips Hue in the docs section about webhooks, but nothing specific… I’ve also found some topics abut homebrigde with references to Philips Hue, but that seems to be tailored to supporting hardware which Homekit doenst support yet and I’m an android user.
Has anyone hooked up their Philips Hue lights to their blynk server and care to share a short how to?
I’ve seen that topic, but I dont have any need for homekit support. So I was hoping there is a more direct way to interact with my lights? Philips has provided a RESTful api, is that usable?
Oke so I found the URL for one of my lights and I am able to turn it on and off and set the brightness using the CLIP API Debugger (provided interface by Philips), with the message body {“on”:true, “bri”:100}.
But I cant get it to work in the webhook widget… Set the output to V0 (not sure why it needs an output), URL same as in the CLIP API Debuger, content type as json and body as {“on”:true, “bri”: /V1/} where V1 is linked to a slider.
I also want the true/false to be set by a button, but not sure how to…
The API works with GET, but I assumed that is used to fetch data? And PUT is used to push data?
And yes I would like to control all my automation from one place (ie Blynk) so I’d like to turn on certain lights and dim them with buttons and sliders in the app, not from a hardware device.
I’m not sure how to figure out the URL for the json format?
I used http://192.168.0.104/api//lights/2/state as the url in the debugger and {“on”:true, “bri”:100} as body, this is unfortunately where my current knowledge ends…
The webhook thinks the URL is formatted wrong… and if I try this in chrome I get the following error:
[{“error”:{“type”:3,“address”:"/lights/2/state&json=%7B%22on%22:true,%22bri%22:255%7D",“description”:“resource, /lights/2/state&json=%7B%22on%22:true,%22bri%22:255%7D, not available”}}]
Actually that should say Blynk, Binance,Thingspeak and EmonCMS etc don’t need a PUT and will work in a browser. That’s becuase they all use tokens and the API for your light might not be clever enough to work with a browser.
That still leaves me kinda lost…
I got it all nice and working with the CLIP API Debugger and their example, but transferring that to the webhook is a mystery… Has no one wanted to control their hue lights directly from the Blynk app?
