Hello all,
I need your help.
I will use a motion detector connected to a Wemos D1 Mini (ESP8622) to control a relay device (Devolo or Sonoff).
To bridge blynk to Devolo or Sonoff, I would like to use IFTT with Webhooks.
Here’s the code. Instead an DHT11, a motion detector will be installed.
/***slo-slo-nodemcu09
07.2016***/
#include <DHT.h>
char auth[] = "dein Blynk Auth Token";
char ssid[] = "dein WLAN-Name";
char pass[] = "dein WLAN-Passwort";
#define DHTPIN 2 // What digital pin we're connected to, d.h. D4 in NodeMCU
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
void sendSensor()
int h = dht.readHumidity();
int t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
So, my question is:
What do I have to do in IFTT, to tell the relay device to power on, if the motion detector changes from 0 to 1 in Blynk?
Best regards
Norman
