Description of the problem status:
At present, the blynk app has a button that turns ON and executes a cool subroutine.
I want to execute a cool subroutine,the button of the blynk must be off before it executes a cool subroutine.
How can I continue to execute a cool subroutine when the blynk app button is ON?
Many thanks.
#include <Arduino.h>
#include <IRremoteESP8266.h>
#include <IRsend.h>
IRsend irsend(4); // An IR LED is controlled by GPIO pin 4 (D2)
char auth[] = "z56s5XG1JxsNebclzJ6Jkuo-vY44TLyA";
char ssid[] = "CPH1607";
char pass[] = "12345678";
irsend.begin();
Serial.begin(9600, SERIAL_8N1, SERIAL_TX_ONLY);
//Serial.begin(9600);
Serial.println( "Blynk Ready!" );
BLYNK_WRITE(V0){
int onoff = param.asInt();
if(onoff == 1){
cool(); //call void cool
void cool()
Serial.print( "cool mode" );
Please edit your post to include triple backticks at the start and end of your code.
Until then, unfortunately, we aren’t going to look into your issue. (Well I won’t at least)
@111105, as @JustBertC said, please put triple backticks at the beginning and end of your code so that it displays correctly.
Also, a better explanation of exactly what it is that you’re trying to achieve is needed before we can give you a clear answer.
when onoff == 1 ,cool subroutine print"cool mode"
But the phone’s button is on, it will be executed once,can’t to continuous print"cool mode"
I want to be able to continue “cool mode” when the button is on
