I have a project on wokwi using ESP32 and I’m having a hard time connecting it to blynk due to the lack of tutorials available,maybe someone can help me tell me what to do.
there is an error library “BlynkEdgent.h” not found, how to solve it…
i use : BLYNK_FIRMWARE_VERSION “0.1.0” in my wokwi code
That’s usually because you have only opened the .ino file of the Edgent example, and are missing all of the others.
If you open the Edgent example in the Arduino IDE you should see multiple tabs, like this:
That’s simply a way for you ro track your own code revisions, and is only used when Blynk.Air OTA updates are pushed to the device.
You should be using Blynk C++ library version 1.1.0 but that is something entirely separate to the BLYNK_FIRMWARE_VERSION variable within the sketch.
You also appear to have deleted some important lines of code from the top of your sketch…
#define BLYNK_TEMPLATE_ID "REDACTED"
#define BLYNK_DEVICE_NAME "REDACTED"
Without adding this data from your template configuration in the Blynk web console your sketch will never work.
You should also un-comment one of these lines, which you also appear top have deleted:
// Uncomment your board, or configure a custom board in Settings.h
//#define USE_WROVER_BOARD
//#define USE_TTGO_T7
//#define USE_ESP32C3_DEV_MODULE
//#define USE_ESP32S2_DEV_KIT
and/or check that the board type you are using in Settings.h matches your board.
But, I’ve be very surprised if an emulator could successfully emulate a device so that it can be provisioned by the Blynk app, so I doubt that the Edgent sketch is the best way forward. You’d be better starting with a simple Blynk WiFi connection sketch instead, creating the device from your template in the Blynk web console, the adding the auth token and your WiFi credentials to the sketch.
Blynk edgent doesn’t work with wokwi, but a non edgent sketch works fine.
You can start with a basic example like this
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char pass[] = "YourPassword";
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
// to avoid delay() function!
Just go to the console/devices/device info tab, copy the template ID, template name, and the auth token, and add it to the sketch, then set the ssid to “Wokwi” and the pass to " " and it should work.
i have successfully connected in wokwi with my WiFi, but there is a little problem in blynk that can’t connect to WiFi. maybe i will try again later. thank you for taking the time to help me
