I’m confused by the question. If you chose the correct SSID and password, why would you WANT to reset them?
I think that he’s saying that if you enter the wrong Blynk Auth code then you’ll never be able to use the widget button in the app to trigger a WifiManager reset so you’ll never be able to correct the Auth code (unless you trigger a WifiManager reset using a physical button, or re-flash the MCU).
When using WifiManager to connect at start-up, sometimes I like to put a simple check in there so that if it does not connect to blynk it will reset the credentials and restart the device.
Blynk.config(blynk_token);
bool result = Blynk.connect();
if (result != true)
Serial.println("BLYNK Connection Fail");
Serial.println(blynk_token);
wifiManager.resetSettings();
ESP.reset();
delay (5000);
Serial.println("BLYNK Connected!! Yay again");
Although when using the WifiManager config with button, I don’t do this. That way you can start your device with or without internet/blynk, and still have it function.
I guess it all depends on the application, and the execution.
This only makes sense if you’re using wifimanager to pass the Blynk credentials to your board. If that is the case, there’s a much simpler workaround. Turn off your router, and boot the ESP. When it doesn’t find the SSID, it will open the AP, and you can correct your mistake.
… or temporary block the particular ESP MAC address, doing so you don’t disrupt the network operation through the router…
Hi there,
I was also looking for that exact combination. but unfortunately your code doesn’t work for me. I get:
C:\Users\admin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.6.3\libraries\ESP8266WebServer\src/ESP8266WebServer.h:33:39: error: previous declaration of ‘HTTPMethod HTTP_HEAD’
enum HTTPMethod { HTTP_ANY, HTTP_GET, HTTP_HEAD, HTTP_POST, HTTP_PUT, HTTP_PATCH, HTTP_DELETE, HTTP_OPTIONS };
what am I doing wrong ?
lg
Thorsten
I’m new to coding and i do have similar issue(code combining).Could you sort it out?
wifimanager code
//Ported to ESP32
#ifdef ESP32
#include <esp_wifi.h>
#include <WiFi.h>
#include <WiFiClient.h>
#define ESP_getChipId() ((uint32_t)ESP.getEfuseMac())
#define LED_ON HIGH
#define LED_OFF LOW
#else
#include <ESP8266WiFi.h> //https://github.com/esp8266/Arduino
//needed for library
#include <DNSServer.h>
#include <ESP8266WebServer.h>
#define ESP_getChipId() (ESP.getChipId())
#define LED_ON LOW
#define LED_OFF HIGH
#endif
// SSID and PW for Config Portal
String ssid = "ESP_" + String(ESP_getChipId(), HEX);
const char* password = "your_password";
// SSID and PW for your Router
String Router_SSID;
String Router_Pass;
// Use false if you don't like to display Available Pages in Information Page of Config Portal
// Comment out or use true to display Available Pages in Information Page of Config Portal
// Must be placed before #include <ESP_WiFiManager.h>
#define USE_AVAILABLE_PAGES false
#include <ESP_WiFiManager.h> //https://github.com/khoih-prog/ESP_WiFiManager
// Onboard LED I/O pin on NodeMCU board
const int PIN_LED = 2; // D4 on NodeMCU and WeMos. GPIO2/ADC12 of ESP32. Controls the onboard LED.
void heartBeatPrint(void)
static int num = 1;
if (WiFi.status() == WL_CONNECTED)
Serial.print("H"); // H means connected to WiFi
Serial.print("F"); // F means not connected to WiFi
if (num == 80)
Serial.println();
num = 1;
else if (num++ % 10 == 0)
Serial.print(" ");
void check_status()
static ulong checkstatus_timeout = 0;
//KH
#define HEARTBEAT_INTERVAL 10000L
// Print hearbeat every HEARTBEAT_INTERVAL (10) seconds.
if ((millis() > checkstatus_timeout) || (checkstatus_timeout == 0))
heartBeatPrint();
checkstatus_timeout = millis() + HEARTBEAT_INTERVAL;
// initialize the LED digital pin as an output.
pinMode(PIN_LED, OUTPUT);
Serial.println("\nStarting");
unsigned long startedAt = millis();
digitalWrite(PIN_LED, LED_ON); // turn the LED on by making the voltage LOW to tell us we are in configuration mode.
//Local intialization. Once its business is done, there is no need to keep it around
// Use this to default DHCP hostname to ESP8266-XXXXXX or ESP32-XXXXXX
ESP_WiFiManager ESP_wifiManager;
// Use this to personalize DHCP hostname (RFC952 conformed)
//ESP_WiFiManager ESP_wifiManager("ConfigOnStartup");
ESP_wifiManager.setMinimumSignalQuality(-1);
// Set static IP, Gateway, Subnetmask, DNS1 and DNS2. New in v1.0.5
ESP_wifiManager.setSTAStaticIPConfig(IPAddress(192,168,2,114), IPAddress(192,168,2,1), IPAddress(255,255,255,0),
IPAddress(192,168,2,1), IPAddress(8,8,8,8));
// We can't use WiFi.SSID() in ESP32as it's only valid after connected.
// SSID and Password stored in ESP32 wifi_ap_record_t and wifi_config_t are also cleared in reboot
// Have to create a new function to store in EEPROM/SPIFFS for this purpose
Router_SSID = ESP_wifiManager.WiFi_SSID();
Router_Pass = ESP_wifiManager.WiFi_Pass();
//Remove this line if you do not want to see WiFi password printed
Serial.println("Stored: SSID = " + Router_SSID + ", Pass = " + Router_Pass);
//Check if there is stored WiFi router/password credentials.
//If not found, device will remain in configuration mode until switched off via webserver.
Serial.print("Opening configuration portal.");
if (Router_SSID != "")
ESP_wifiManager.setConfigPortalTimeout(60); //If no access point name has been previously entered disable timeout.
Serial.println("Timeout 60s");
Serial.println("No timeout");
// SSID to uppercase
ssid.toUpperCase();
//it starts an access point
//and goes into a blocking loop awaiting configuration
if (!ESP_wifiManager.startConfigPortal((const char *) ssid.c_str(), password))
Serial.println("Not connected to WiFi but continuing anyway.");
Serial.println("WiFi connected...yeey :)");
digitalWrite(PIN_LED, LED_OFF); // Turn led off as we are not in configuration mode.
// For some unknown reason webserver can only be started once per boot up
// so webserver can not be used again in the sketch.
#define WIFI_CONNECT_TIMEOUT 30000L
#define WHILE_LOOP_DELAY 200L
#define WHILE_LOOP_STEPS (WIFI_CONNECT_TIMEOUT / ( 3 * WHILE_LOOP_DELAY ))
while ( (WiFi.status() != WL_CONNECTED) && (millis() - startedAt < WIFI_CONNECT_TIMEOUT ) )
#ifdef ESP32
WiFi.mode(WIFI_STA);
WiFi.persistent (true);
// We start by connecting to a WiFi network
Serial.println(Router_SSID);
WiFi.begin(Router_SSID.c_str(), Router_Pass.c_str());
#endif
int i = 0;
while((!WiFi.status() || WiFi.status() >= WL_DISCONNECTED) && i++ < WHILE_LOOP_STEPS)
delay(WHILE_LOOP_DELAY);
Serial.print("After waiting ");
Serial.print((millis()- startedAt) / 1000);
Serial.print(" secs more in setup(), connection result is ");
Serial.print("connected. Local IP: ");
//else
// Serial.println(ESP_wifiManager.getStatus(WiFi.status()));
// put your main code here, to run repeatedly
check_status();
Code which i want to combine with wifimanager:-
#include <ArduinoJson.h>
#include <ESP8266WiFiMulti.h>
#include <WebSocketsClient.h>
#include <Hash.h>
// @@@@@@@@@@@@@@@ You only need to midify modify wi-fi and domain info @@@@@@@@@@@@@@@@@@@@
const char* ssid = "enter your ssid name"; //enter your ssid/ wi-fi(case sensitiv) router name - 2.4 Ghz only
const char* password = "enter ssid password"; // enter ssid password (case sensitiv)
char host[] = "espiot.herokuapp.com"; //enter your Heroku domain name like "espiot.herokuapp.com"
int port = 80;
char path[] = "/ws";
ESP8266WiFiMulti WiFiMulti;
WebSocketsClient webSocket;
const int relayPin = 16;
DynamicJsonBuffer jsonBuffer;
String currState;
int pingCount=0;
void webSocketEvent(WStype_t type, uint8_t * payload, size_t length) { //uint8_t *
switch(type) {
case WStype_DISCONNECTED:
Serial.println("Disconnected! ");
Serial.println("Connecting...");
webSocket.begin(host, port, path);
webSocket.onEvent(webSocketEvent);
break;
case WStype_CONNECTED:
Serial.println("Connected! ");
// send message to server when Connected
webSocket.sendTXT("Connected");
break;
case WStype_TEXT:
Serial.println("Got data");
//data = (char*)payload;
processWebScoketRequest((char*)payload);
break;
case WStype_BIN:
hexdump(payload, length);
Serial.print("Got bin");
// send data to server
webSocket.sendBIN(payload, length);
break;
Serial.setDebugOutput(true);
pinMode(relayPin, OUTPUT);
for(uint8_t t = 4; t > 0; t--) {
Serial.println();
Serial.println();
//Serial.println(ssid);
WiFiMulti.addAP(ssid, password);
//WiFi.disconnect();
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
delay(100);
Serial.println("Connected to wi-fi");
webSocket.loop();
//If you make change to delay mak sure adjust the ping
delay(2000);
// make sure after every 40 seconds send a ping to Heroku
//so it does not terminate the websocket connection
//This is to keep the conncetion alive between ESP and Heroku
if (pingCount > 20) {
pingCount = 0;
webSocket.sendTXT("\"heartbeat\":\"keepalive\"");
else {
pingCount += 1;
void processWebScoketRequest(String data){
JsonObject& root = jsonBuffer.parseObject(data);
String device = (const char*)root["device"];
String location = (const char*)root["location"];
String state = (const char*)root["state"];
String query = (const char*)root["query"];
String message="";
Serial.println(data);
if(query == "cmd"){ //if query check state
Serial.println("Received command!");
if(state=="on"){
digitalWrite(relayPin, HIGH);
message = "{\"state\":\"ON\"}";
currState = "ON";
}else{
digitalWrite(relayPin, LOW);
message = "{\"state\":\"OFF\"}";
currState = "OFF";
}else if(query == "?"){ //if command then execute
Serial.println("Received query!");
int state = digitalRead(relayPin);
if(currState=="ON"){
}else{
}else{//can not recognized the command
Serial.println("Command is not recognized!");
Serial.print("Sending response back");
Serial.println(message);
webSocket.sendTXT(message);
if(query == "cmd" || query == "?"){webSocket.sendTXT(message);}
The problem started from ESP8266 core 2.6.0+ as new declaration of HTTP_HEAD
conflicts with the one in WiFiManager.
You can fix the issue by using this new WiFiManager (latest version v1.0.5)
I just saw you’re using ESP_WiFiManager sample code. It’s better to post in a new topic, not in the very old one.
I just create a new topic just to support forum members using ESP_WiFiManager
Please repost your issue there. Many people and I certainly will try to help.
