I uploaded the Blynk.Edgent sketch in my board. And then I am connecting it to Blynk application after uploading the code. But my wifi is unstable because of the signal. But then it said to my Serial connected to “Ikaw lamang” my wifi name, but in my Blynk application, it does not show that it connects because it has nothing. And now when I upload a new code, it always says in my serial monitor after I uploaded the code and press the EN button, connecting to “Ikaw lamang” my wifi name. I am using Arduino IDE 2.0.1. Thank you for helping
If you are asking how do you re-provision your device with a different SSID and WiFi password then you should read this…
If that’s not what you’re asking then I think you need to rephrase your question so that it’s clear what it is that you are trying to achieve.
Thank you, this helped me.
