The file is a CSV - Comma Separated Variables - so if you open it correctly in Excel then each variable will be in a separate column. I guess that’s what you meant when you said…
If you also record and run a macro to change the formatting, so that UNIX dates appear as regular dates and the temperature (?) values appear to one decimal place, then your data will also be much easier to read and work with.
