Hi guys.
I can’t understand what the problem is and where the bug is. I put one picture on the tile, and some other appears. The picture in development mode is one, in operation it is different. What is it and how can I change it?
BR,
Artem.
Hi guys.
BR,
Artem.
Hi Tema
I have added an arow
Then tile and chose Button
On my phone it behave strange , some times, then I close the APP and start again and you will see the change
/Torben
Yes TorNor, that’s right, I did it before, Choosing Tile design - Button - Picture on the button when Turned On and when Turned Off. But the picture doesn’t change.
Artem.
Hi Tema
It seems like I was lucky last day, same here again, on another device.
It is a BUG, @ Dmitriy
10min latere
I found out what I did last day.
Then choose the Icon you want, as a workaround
/Torben
Hi TorNor.
I also managed to change the icon. But the meaning of this icon is when the Button is pressed - one icon, when the Button is off - another icon. That is there should be two states and accordingly two icons, but you cannot make two icons. In short - this is a bug, it needs to be fixed.
BR,
Artem.
