my whole code for my projct is…
http://twitter.com/blynk_app
WARNING!
It's very tricky to get it working. Please read this article:
http://help.blynk.cc/hardware-and-libraries/arduino/esp8266-with-at-firmware
You’ll need:
- Blynk App (download from AppStore or Google Play)
- Arduino Uno board
example.
//uncomment this line if using a Common Anode LED#define COMMON_ANODE
#include <ESP8266_Lib.h>
char auth[] = "b7d6a71cdaef45b5844f5695f57badb8";
char ssid[] = "rd";
char pass[] = "rohit2237424";
int D2, D3;
boolean buttonState = HIGH; //set the initial direction of the relays, see below for if(HIGH) logic
#define EspSerial Serial
//#include <SoftwareSerial.h>
// Your ESP8266 baud rate:
#define ESP8266_BAUD 115200
ESP8266 wifi(&EspSerial);
const int redPin = 10;
const int greenPin = 11;
const int bluePin = 12;
unsigned int rgbColour[3];
// Set ESP8266 baud rate
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(7, OUTPUT);
pinMode(8, OUTPUT);
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
digitalWrite(12, HIGH);
digitalWrite(10, HIGH);
digitalWrite(11, HIGH);
//Blynk.begin(auth, wifi, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, wifi, ssid, pass, IPAddress(192,168,1,100), 8442);
// to avoid delay() function!
// Start off with red.
BLYNK_WRITE(V1)
if (param.asInt()==1) {
digitalWrite(7, HIGH);
digitalWrite(8, HIGH);//button presed
digitalWrite(7, LOW);
digitalWrite(8, LOW);//button released
BLYNK_WRITE(V2)
digitalWrite(2, HIGH);
digitalWrite(6, HIGH);//button presed
digitalWrite(2, LOW);
digitalWrite(6, LOW);//button released
BLYNK_WRITE(V3)
digitalWrite(4, HIGH);
digitalWrite(5, HIGH);//button presed
digitalWrite(4, LOW);
digitalWrite(5, LOW);//button released
BLYNK_WRITE(V4)
digitalWrite(3, HIGH);//button presed
digitalWrite(3, LOW);//button released
BLYNK_WRITE(V6)
int pinvalue = param.asInt();
if (pinvalue==1)
rgbColour[0] = 0;
rgbColour[1] = 0;
rgbColour[2] = 0;
// Choose the colours to increment and decrement.
for (int decColour = 0; decColour < 3; decColour += 1) {
int incColour = decColour == 2 ? 0 : decColour + 1;
// cross-fade the two colours.
for(int i = 0; i < 255; i += 1) {
rgbColour[decColour] -= 1;
rgbColour[incColour] += 1;
setColourRgb(rgbColour[0], rgbColour[1], rgbColour[2]);
delay(5);
else {
void setColourRgb(unsigned int red, unsigned int green, unsigned int blue) {
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
