tried the code only the temperature u ask and here the serial monitor…quite many failed
Not very reliable.
Set Serial Monitor baud rate to 115200.
Add your WiFi and token details to the following sketch. I have hacked it so it can cope with bad readings.
#define BLYNK_PRINT Serial /* Comment this out to disable prints and save space */
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define DHTPIN 0 // D3
DHT dht(DHTPIN, DHTTYPE);
float setpoint = 0;
bool relaystatuschanged = false;
const int relayPin = 5; // D1
float backuptemperature = 99.9; // set artificially high
BLYNK_WRITE(V0)// slider widget
setpoint = param.asFloat();
relaystatuschanged = true;
void sendSensor()
if (isnan(t))
Serial.println("Failed to read temperature!");
//return;
t = backuptemperature;
backuptemperature = t;
Blynk.virtualWrite(V5, t);
if((setpoint >= t) && (relaystatuschanged == true))
digitalWrite(relayPin, 0); // assuming relay is active LOW
digitalWrite(relayPin, 1); // assuming relay is active LOW
pinMode(relayPin, OUTPUT);
dht.begin();
timer.setInterval(5000L, sendSensor); // Setup a function to be called every 5 seconds
and the relay keep going ON
I coded it that way as a sign that there is a problem.
As long as it gets a good temperature reading the first time it reads the sensor it shouldn’t be a problem.
Let’s try a revised sketch without the relay connected.
// norelays.ino
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
void sendSensor()
if (isnan(t))
//return;
if(t != 99.9)
dht.begin();
going ON and OFF or just staying ON?
it stays ON
OK this one compiles. Don’t forget to disconnect relay. I just want to see a screen full of good temperature readings.
// norelays.ino
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
void sendSensor()
if (isnan(t))
//return;
if(t != 99.9)
dht.begin();
Did you copy and paste my last sketch exactly and have you disconnected the relay?
I can’t understand why the DHT sensor is not giving any readings with Blynk.
yes i have copied exactly without any modification and i also had disconnect completely the relay. i also try changing the sensor with spare
One last try:
// norelayswithloop.ino
#include <DHT.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
long lastreading;
dht.begin();
lastreading = millis();
if(lastreading >= millis() + 5000)
if (isnan(t))
if(t != 99.9)
Any better if you change setup() to:
dht.begin();
still the same as above, nothing happen
Ok this “works”.
#include <DHT.h>
char auth[] = "xxx";
char ssid[] = "xxx";
char pass[] = "xxx";
#define DHTPIN 14 //
int lastreading = millis();
dht.begin();
if ((millis() - lastreading) >= 5000)
if (isnan(t))
if(t < 99)
Do you still have Serial Monitor set as 115200 baud?
It runs here for me (without a DHT11).
if i change to 115200 baud the serial monitor would go blank without any word
