How to add a new wifi network in Blynk 2.0
Hello friends, i successfully connected a device to a wifi network and it worked nicely. Now i want to add a new wifi network . So i erased the first wifi network by using flash button.
hey there,
https://docs.blynk.io/en/getting-started/activating-devices/blynk-edgent-wifi-provisioning
After you have reset the board and the device reboots ! It shows up as an access point. You need to connect to it and follow the procedure you did the first time by giving the wifi credentials.
Or you can reconfigure the device inside the app itself. Give it a try. No need to press flash button.
