Dear Sirs,
looking at the release announcement for the blynk library we see:
“Important. When BlynkTimer struggles to run multiple times (due to a blocked loop), it just skips all the missed intervals, and calls your function only once. This now differs from SimpleTimer, which could call your function multiple times in this scenario.”
What does it means and how ( if ) can we have the “normal” SimpleTimer, operation in case that the new behavior of BlynkTimer is not desired?
Certainly yes but in order to optimize the memory etc usage, now that the simpletimer became blynktimer it is better to stick with it. So I think the question still looking for an answer!
Sure it is. Initially blynk just include it in the “blynk library” distribution, but at the latest library release, they have changed a little bit. If you go at theirs GitHub you can see exactly what the have altered. I am not programmer though…
Well, it is as clearly stated, as it can be. I hit this behaviour before (when using SimpleTimer instead of BlynkTimer) and it was quite an unpleasant “feature”: Lets Initialise some Interval timer with timer.setInterval() and then call a blocking function: Let it be Blynk.begin(). Now the SimpleTimer will trigger all the timed occurences, but because there is no multitasking, it will not execute the assigned routine, just queue them. Now as soon as our Blynk.begin() will release the task stack (or whatewer it is named) our queued tasks starts to run: one by one, ignoring the preset timer… Is it expected?? NO WAY!!. That is why I dropped SimpleTimer in some tasks and were using simple if… then…
Now, as the BlynkTimer supposedly corrects this (not tried yet this specific, but not rare situation) I started to use it (yet not always )
I hope it is clear now…
