I am experiment and learn.
Is making a major task with your help and the beach there and áhvað to go there to learn more and test me.
I am also practicing for Blynk app lcd
It functions all I see value in Blynk app but need the correct value for psi.
using this code.
Social networks: http://www.fb.com/blynkapp
http://twitter.com/blynk_app
Output any data on LCD widget!
App project setup:
LCD widget, switch to ADVANCED mode, select pin V1
#include <Ethernet.h>
#define W5100_CS 10
#define SDCARD_CS 4
//int sensorPin = A5; // select the input pin for the potentiometer
//int ledPin = V9; // select the pin for the LED
//int sensorValue = 0; // variable to store the value coming from the sensor
char auth[] = "3295d2122335428a8a8877a04a64367b";
WidgetLED led1(V7);
int Pressure = A5;
int val = 0;
int val1 = 0;
int val2 = 0;
WidgetLCD lcd(V1);
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth, IPAddress(192,168,10,3)); // For more options, see Boards_Ethernet/Arduino_Ethernet_Manual example
// declare the ledPin as an OUTPUT:
pinMode(Pressure, INPUT); // sets the analogue pin 1 as input
//lcd.clear(); //Use it to clear the LCD Widget
lcd.print(4, 0, sensorPin); // use: (position X: 0-15, position Y: 0-1, "Message you want to print")
lcd.print(4, 1, val);
// Please use timed events when LCD printintg in void loop to avoid sending too many commands
// It will cause a FLOOD Error, and connection will be dropped
BLYNK_READ(V6)//pressure reading
int val = analogRead(5);
val = map(val, 0, 1080, 0, 35);
Blynk.virtualWrite(6, val);
//GREEN LED
if (val > 30){//If val = greater than 100, LED turns green
Blynk.setProperty(V6, "color", "#ff0033");
led1.on();//LED On
} else {//If val = less than 30 LED turns off
Blynk.setProperty(V6, "color", "#33cc33");
led1.on();//LED On
Serial.print(A5);
