Hi
I need help to try and understand how to use IF statements please using with Blynk, using Arduino i understand the concept and within reason i can use them fine, but with Blynk i don’t understand how to build the IF statement
Example, i want to create an IF that says if Temp is more than Numeric Input Settings box in Blynk, that has Value of 26 fro example then run code for LED strip a certain colour? the else statements i am fine with once i understand the concept of IF using Blynk…
PS, i am not asking for anyone to do the code for me, just how the concept works in Blynk please i have tried to do this myself, and looked on google and so on, but i still can’t get this to work.
I am using NodeMCU to do this project…
PS the reason i want to use Blync is so i can remove physical buttons from my original project and then put all the part in a smaller box or tube… I am making a Spirit Box / Tube i have added the code i have done just using Arduino using Mega and this works fine… i just want to reduce the size of the box now and i think Blynk would be the perfect solution for this, and also i can get live data
and save the data too.
Peter
NodeMCU has weird pin mapping.
Pin numbers written on the board itself do not correspond to ESP8266 GPIO pin numbers. We have constants defined to make using this board easier:
static const uint8_t D0 = 16;
static const uint8_t D1 = 5;
static const uint8_t D2 = 4;
static const uint8_t D3 = 0;
static const uint8_t D4 = 2;
static const uint8_t D5 = 14;
static const uint8_t D6 = 12;
static const uint8_t D7 = 13;
static const uint8_t D8 = 15;
static const uint8_t D9 = 3;
static const uint8_t D10 = 1;
#include <DHT.h>
#include <Adafruit_NeoPixel.h>
//#include <SPI.h>
char auth[] = "---------------------------"; // Used for Blynk
char ssid[] = "------";
char pass[] = "--------";
#define DHTPIN D3 // What digital pin we're connected to
#define DHTTYPE DHT22 // DHT 22
#define PIN D4 // pin on the Arduino is connected to pin 3 for NeoPixels
#define LDRPin A0 // select the input pin for ldr A0
#define DELAYVAL 500 // Time (in milliseconds) to pause between pixels
Adafruit_NeoPixel strip = Adafruit_NeoPixel(12, PIN, NEO_GRB + NEO_KHZ800);
DHT dht(DHTPIN, DHTTYPE);
int PlusTempNumber = 0;
BLYNK_WRITE(V90)// Numbers input box
PlusTempNumber = param.asInt();
int t = dht.readTemperature(); // or dht.readTemperature(HIGH) for Fahrenheit
if (t >= V90) {
for (int i = 12; i > 0; i--) {
strip.setPixelColor(i, strip.Color(250, 0, 0)); // Red color.
strip.show();
strip.setPixelColor(i, strip.Color(0, 0, 0)); // No color.
strip.show();
void sendSensor()
float h = dht.readHumidity();
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
dht.begin();
strip.begin();
strip.show();
//////////// Below Code is the what i want to reduce using Blynk i don't need help on this i have added just so you know what i want to achieve using Blynk reduce the code down //////////////////
#include <TEA5767Radio.h>
#include <Button.h>
#include <Wire.h>
#include <Adafruit_MLX90614.h>= // Include IR thermometer library
Adafruit_MLX90614 mlx = Adafruit_MLX90614();
#include <SoftwareSerial.h> // Needed by the EMIC2 library
//#include <SD.h> // Needed by the EMIC2 library, though not utilized in this example
#include "EMIC2.h"
TEA5767Radio radio = TEA5767Radio();
#define PIXELS 572 // Number of NeoPixels
#define PIN 43 // pin on the Arduino is connected to pin 3 for NeoPixels
#define Radio 40 // Mosfet Pin
#define RX_PIN 50 // Connect SOUT pin of the Emic 2 module to the pin
#define TX_PIN 52 // Connect SIN pin of the Emic 2 module to the TX pin
EMIC2 emic; // Creates an instance of the EMIC2 library
//---< Neo Pixels >---//
Adafruit_NeoPixel strip = Adafruit_NeoPixel(PIXELS, PIN, NEO_GRB + NEO_KHZ800);
//---< Temp Sensor >---//
// BME280 mySensor ; //Uses I2C address 0x76 (jumper closed) // temp sensor
// set the LCD address to 0x27 for a 20 chars 4 line display
LiquidCrystal_I2C lcd (0x27, 20, 4);
/*-----( Declare Variables )-----*/
// const int chipSelect = 4;
Button TempButton1(44); // Used to Higher Temp Connect your button between pin number and GND
Button TempButton2(45); // Used to Lower Temp Connect your button between pin number and GND
Button RadioButton1(46); // Used to Higher FRSpeedScan Connect your button between pin number and GND
Button RadioButton2(47); // Used to Lower FRSpeedScan Connect your button between pin number and GND
const int SensorsPinArray[4] = {35, 37, 39, 41}; // Sensor PIN array
int PlusAlarmTemp = 80; // starting default set point for temp adjustments
int MinusAlarmTemp = 60; // starting default set point for temp adjustments
int FRSpeed = 100; // FRSpeedScan default speed
int sensorPin = A1; // select the input pin for ldr
int sensorValue = 0; // variable to store the value coming from the sensor
Serial.begin(9600); // Used to enable Print data to serial port 9600 is port speed
for (int i = 0 ; i < 4 ; ++i) {
int Sensor = (digitalRead(SensorsPinArray[i]));
pinMode(SensorsPinArray[4], INPUT);
emic.begin(RX_PIN, TX_PIN);
emic.setRate(180);
emic.setVolume(40);
emic.setVoice(2); // Sets the voice (9 choices: 0 - 8)
TempButton1.begin(); // Used to Higher Temp
TempButton2.begin(); // Used to Lower Temp
RadioButton1.begin(); // Used to Higher FRSpeedScan
RadioButton2.begin(); // Used to Lower FRSpeedScan
lcd.init(); // initialize the lcd
lcd.backlight(); //Backlight ON if under program control
pinMode(Radio, OUTPUT); // Radio control pin as output
digitalWrite(Radio, HIGH); // Turn the radio On
//pinMode(SensorPins, INPUT);
strip.begin(); // Neo Pixels Begin
strip.setBrightness(3); // Brightness control for Neo Pixels
strip.clear();
Wire.begin();
mlx.begin(); // MLX90614 IR thermometer Begin
// mySensor.setI2CAddress(0x76); //Connect I2C sensor
// mySensor.beginI2C();
void SetTempPlus() //---< Set Plus Temp Start >---//
if (TempButton1.pressed())
PlusAlarmTemp = PlusAlarmTemp - 1; //Raise PlusAlarmTempHi by one
//---< Set Temp Plus End >---//
void SetTempMinus() //---< Set Minus Temp Start >---//
if (TempButton2.pressed())
MinusAlarmTemp = MinusAlarmTemp + 1; //Lower PlusAlarmTempLow by one
//---< Set Temp Minus End >---//
void FRSpeedScan() //---< Set FR Speed Scan Start >---//
if (RadioButton1.pressed())
FRSpeed = FRSpeed + 40; //Raise PlusAlarmTempHi
if (RadioButton2.pressed())
FRSpeed = FRSpeed - 20; //Lower PlusAlarmTempLow
//---< Set FR Speed Scan End >---//
void MovementPixels() //---< Start Used for all movement sensors >---//
for (int i = 563; i > 0; i--) {
strip.setPixelColor(i, strip.Color(230, 80, 0)); // minus color.
}//---< Start Used for all movement sensors >---//
void allpixels_off() //---< Turns All Pixels Off Actions >---//
for (int i = PIXELS; i > 0; i--) {
strip.setPixelColor(i, strip.Color(0, 0 , 0)); // minus color.
//---< Turns All Pixels Off Actions End >---//
void TempDataPlusReading() //---< Plus Temperature Actions >---//
int Temp = mlx.readObjectTempF();
lcd.setCursor(1, 0); //Start at character 1 on line 0
lcd.print("TEMP ");
lcd.setCursor(6, 0); //Start at character 6 on line 0
lcd.print(mlx.readObjectTempF(), 0);
lcd.setCursor(1, 1); //Start at character 1 on line 1
lcd.print("SET TEMP + ");
lcd.setCursor(14, 1); //Start at character 14 on line 1
lcd.print(PlusAlarmTemp);
lcd.setCursor(1, 3); //Start at character 1 on line 3
lcd.print("SET FREQ ");
lcd.setCursor(13, 3); //Start at character 13 on line 3
lcd.print(FRSpeed);
if (Temp >= PlusAlarmTemp)
ForwardFrequency();
digitalWrite(Radio, LOW); // Turn the radio pin LOW
delay(50);
digitalWrite(Radio, HIGH); // Turn the radio pin HIGH
for (int i = 572; i > 0; i--) {
strip.setPixelColor(i, strip.Color(150, 0, 0)); // minus color.
strip.show(); // This sends the updated pixel color to the hardware.
emic.speak("Warning High Temperature Change");
allpixels_off();
//---< Plus Temperature Actions End >---//
void TempDataMinusReading() //---< Temperature Actions >---//
lcd.setCursor(1, 2); //Start at character 1 on line 2
lcd.print("SET TEMP - ");
lcd.setCursor(14 , 2); //Start at character 14 on line 2
lcd.print(MinusAlarmTemp);
if (Temp <= MinusAlarmTemp)
ReverseFrequency();
digitalWrite(Radio, LOW); // Turn the MOSFET Switch OFF
delay(50);
digitalWrite(Radio, HIGH); // Turn the MOSFET Switch On
strip.setPixelColor(i, strip.Color(0, 0, 150)); // minus color.
void LdrSensor() // ---< LDR sensor start >---//
sensorValue = analogRead(sensorPin); // read the value from the sensor:
lcd.setCursor(9, 0); //Start at character 1 on line 0
lcd.print("LGT ");
lcd.setCursor(13, 0); //Start at character 6 on line 0
lcd.print(sensorValue); //prints the values coming from the sensor on the screen
if (sensorValue > 400)
emic.speak("Warning ambient light detected");
if (sensorValue < 700) //setting a threshold value
LdrReverseFrequency();
delay(50);
allpixels_off();
// ---< LDR sensor end >---//
void ForwardFrequency() //---< Sweep FM Range Forward Actions >---//
int threshold = 1008;
for ( int i = 810 ; i < 1008 ; i++) {
float Frequency = i / 10.0 ;
radio.setFrequency(Frequency); // pick your own frequency
lcd.setCursor(13 , 3); //Start at character 10 on line 1
lcd.print(Frequency);
delay(FRSpeed);
//---< Sweep FM Range Forward Actions End >---//
void ReverseFrequency() // Radio sweep FM range reverse//
int threshold = 1007;
for ( int i = 1008 ; i >= 850 ; i-- ) {
lcd.println(Frequency);
delay(FRSpeed);
//--- Radio sweep FM range reverse End ---//
void CapSensordataAll() //--- All Sensors PIN array start---//
int RfSensors = (digitalRead(SensorsPinArray[i]));
if (RfSensors == HIGH) {
MovementPixels();
else {
allpixels_off();
//--- All Sensors PIN array end---//
void LdrReverseFrequency() // Ldr sweep FM range reverse//
//--- Ldr sweep FM range reverse End ---//
SetTempPlus(); // Set Temp Plus Void
SetTempMinus(); // Set Temp Minus Void
FRSpeedScan(); // FR Speed Scan Void
TempDataPlusReading(); // Plus Temp Data void
TempDataMinusReading(); // Minus Temp Dat Void
CapSensordataAll();
LdrSensor(); // LDR Sensor Void
//FrontSensor(); // Front Sensor affect all Orange pixels when HIGH
//BackSensor(); // Back Sensor affect all Yellow pixels when HIGH
//LeftSensor(); // Left Sensor affect all Pink pixels when HIGH
//RightSensor(); // Right Sensor affect all Cyan pixels when HIGH
