Hello guys!
Some guys can help me use vitural pin in Blynk app. I still dont understand !
Thanks for your helping
Hello guys!
Your title is completely wrong in reference to your question. And searching the forums for âvirtual pin helpâ would have led you to answers.
For example, check out this link >here<
Hello Gunner do you have skype ? Can we have a short conversation ?
We can communicate here
Hello guy !
I have a nodeMCU and I still dont understand how can use LCD in Blynk.
I give example that: When i click button the LCD will show âOpen Doorâ and when I dont the LCD will show âClosed Doorâ. By the way, I dont understand how to use Virtual Pin.
Thanks for your helping.
It really is not complicated, however you havenât yet checked out the link (links are in green) that I already sent you in my first post (above) about virtual pins.
You can also find other great examples, including LCD, in Blynkâs example browser >here<. That will be your best way of understanding how all the widgets and virtual pins work.
Load and try a few of the examples, then try modifying them for your needs. And then if you need any help with a specific issue, you can post your code. >please follow these guidelines < And then we (fellow Blynk users) will try and help.
Just an FYI, there is unfortunately no color coding on links from the phone, so he might have misunderstood the âhereâ is actually the link
Edit: Blasted SwiftKey always have to edit posts. Writing in 3 different languages screws it up sometimes I guess >.<
Ah⌠thanks for the insight
I have been occasionally been bracketing links like >this< as well⌠I guess I shall start doing that all the time now ![]()
