Hi all,
How do I merge the example Servo code with the ESP8266Direct_Connect example code?
Here is both examples:
* Downloads, docs, tutorials: http://www.blynk.cc
* Blynk community: http://community.blynk.cc
* Social networks: http://www.fb.com/blynkapp
* http://twitter.com/blynk_app
* This example shows how to connect to ESP8266 directly
* without using intermediate server.
* Please note: this example is for experienced users.
* NOTE: Blynk Apps currently do not support direct TCP connection.
* Wait for new updates!
//#define BLYNK_DEBUG
#include <BlynkSimpleUserDefined.h>
// Uncomment this to set WiFi to Access Point mode:
#define WIFI_MODE_AP
// Set these to your credentials.
const char ssid[] = "Blynk-AP"; // WiFi name
const char password[] = "12345678"; // WiFi password
// Set port of the server
const int port = 8442;
// Auth token doesn't matter with direct-connect
char auth[] = "";
// Description of the dashboard
char profile[] = R"raw({"dashBoards":[
{"id":1,"name":"Direct connect","boardType":"ESP8266","widgets":[
{"id":2,"type":"DIGIT4_DISPLAY","pinType":"VIRTUAL","pin":9,"x":5,"y":1,"frequency":1000}
]})raw";
// Virtual handlers for our widgets...
BLYNK_READ(V9) {
Blynk.virtualWrite(9, millis() / 1000);
// Next goes the hard stuff: connection management, etc...
WiFiServer server(port);
WiFiClient client;
// This function is used by Blynk to receive data
size_t BlynkStreamRead(void* buf, size_t len)
return client.readBytes((byte*)buf, len);
// This function is used by Blynk to send data
size_t BlynkStreamWrite(const void* buf, size_t len)
return client.write((byte*)buf, len);
// Setup your connection here.
Serial.println();
Blynk.begin(auth);
Blynk.setProfile(profile);
#ifdef WIFI_MODE_AP
BLYNK_LOG("Configuring WiFi access point: %s", ssid);
WiFi.softAP(ssid, password);
Serial.print("AP IP address: ");
Serial.println(WiFi.softAPIP());
#else
BLYNK_LOG("Connecting to WiFi %s", ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println();
Serial.print("STA IP address: ");
#endif
server.begin();
BLYNK_LOG("Listening on port: %d", port);
client = server.available();
// Make sure that Blynk.run() is called
// only when the connection is established
if (client) {
Serial.print("Client connected from ");
Serial.print(client.remoteIP());
Serial.print(":");
Serial.println(client.remotePort());
// Wait for connection
unsigned long start = millis();
while (!client.connected() && (millis() - start < 1000)) {
delay(5);
// Go!!!
Blynk.startSession();
while (client.connected()) {
// Okay, handle Blynk protocol
bool hasIncomingData = (client.available() > 0);
// Tell Blynk if it has incoming data
// (this allows to skip unneeded BlynkStreamRead calls)
if (!Blynk.run(hasIncomingData)) {
Serial.print("Error happened or disconnected.");
break;
client.stop();
Serial.println("Client disconnected.");
[/code]
And the other example script:
* Rotate a servo using a slider!
* App dashboard setup:
* Slider widget (0...180) on V3
#include <Ethernet.h>
#include <Servo.h>
Servo servo;
Blynk.begin(auth);
servo.attach(9);
BLYNK_WRITE(V3)
servo.write(param.asInt());
