Hello folks,
Yes, I searched the forum b4 posting, could not find the answer I am looking for. Here is my question: Using value display, how do I round to two decimal places?
iOS 10
Iphone 7+
Thank you.
Alex
Hello folks,
iOS 10
Iphone 7+
Thank you.
Alex
What controller are you using? Arduino?
KevsyBear:
I am using the ESP8266 HUZZAH by AdaFruit, sorry for not specifying that, and thank you for your quick replay.
Not sure but try with:
temperature = round(temperature*100)/100;
Being “temperature” the float you want to round for example.
After that, send this value to the “Value display” using a Virtual Pin
Thank you, psoro, for your reply, I will try that, and update this post later with results.
I think if you use Round() you will not get 2 decimals. Only whole Numbers.
try
temperature = (temperature,2)
If it is just the visual representation you require then:
http://docs.blynk.cc/#widgets-displays-labeled-value
/pin.##/ - displays the value with two decimal places (12.68)
If you actually want to modify a number then it is a combination of float and int with plus 5 for rounding * and / by 100 and 100.0 etc
dennymoney:
This works very well for Serial.print, in my case, I am trying to display values on the Iphone. I have not figured out how to round to 2 decimal .
Costas:
Thank you for your reply, this works for Labeled Value Display, but I cannot figure out how to round to two decimal using Value Display only.
float testfloat = 23.673;
int testint = testfloat * 1000;
testint = testint + 50; // for rounding
testfloat = testint / 1000.0;
Try something like the above.
I know this is an old post, but just thought I would add what I did to resolve this issue for reference.
float TankTemp = sensors.getTempCByIndex(0) + CalTemp;
char T[6];
sprintf(T, "%.2f", TankTemp);
this prints to 2 decimal points.
