I am trying to switch the relay off/on with the ESP8266 NodeMCU via a wifi connection.
The issue is whenever i power on the NodeMCU the relay switch turns on as well. So i want the relay switch to be turned off whenever i power the esp on or when i press the reset button. Here is the code.
char auth[] = "";
char ssid[] = "";
char pass[] = "";
// to avoid delay() function!
As I said, you’d need to modify your code.
Something like this should get you going…
char auth[] = "";
char ssid[] = "";
char pass[] = "";
#define relay_pin 5 // Relay pin connected to GPIO5 (Pin D1) - change as required
BLYNK_WRITE(V1) // callback function that is triggered automatically when the widget attached to pin V1 changes
int widget_value = param.asInt(); // capture the value from the widget
if (widget_value = 1)
digitalWrite(relay_pin,HIGH); // Turn the relay on
digitalWrite(relay_pin,LOW); // Turn the relay off
pinMode(relay_pin,OUTPUT);
The code assumes that your relay is attached to GPIO1 (D5) and that you have a button widget (in Switch mode) attached to pin V1.
I think his problem come from the choice of the mcu pinout.
Remember, some pins are high at MCU start !
He has to use safe pins.
Blynk V2 is on the way
