How do I create a device from template on the App
There’re 3 options when I press Add new device
there’s no option to create device from template as in the web page
Can I create device from template on App?
Thanks.
@11159 yes, you need to select “Connect to Wi-Fi” in case Wi-Fi enabled devices. If the device doesn’t have Wi-Fi, you can use Static Tokens claiming from the mobile app (however this is only PRO plan feature). On non-PRO plan, you can add the device with static token only via the web or via the quickstart guide by setting the correct Template Id in your sketch.
Got it, thanks.
