I’m using and adafruit feather huzzah32 as a bluetooth module and while I can get it to connect to the blynk app, I have no idea how to write the sensor data to a virtual pin since that’s the only way to communicate with an I2C connection. Can anyone help me modify this to make it send data to a virtual pin?
#include "Adafruit_PM25AQI.h"
Adafruit_PM25AQI aqi = Adafruit_PM25AQI();
// Wait for serial monitor to open
while (!Serial) delay(10);
Serial.println("Adafruit PMSA003I Air Quality Sensor");
// Wait one second for sensor to boot up!
// If using serial, initialize it and set baudrate before starting!
// Uncomment one of the following
//Serial1.begin(9600);
//pmSerial.begin(9600);
// There are 3 options for connectivity!
if (! aqi.begin_I2C()) { // connect to the sensor over I2C
//if (! aqi.begin_UART(&Serial1)) { // connect to the sensor over hardware serial
//if (! aqi.begin_UART(&pmSerial)) { // connect to the sensor over software serial
Serial.println("Could not find PM 2.5 sensor!");
while (1) delay(10);
Serial.println("PM25 found!");
PM25_AQI_Data data;
if (! aqi.read(&data)) {
Serial.println("Could not read from AQI");
delay(500); // try again in a bit!
return;
Serial.println("AQI reading success");
Serial.println();
Serial.println(F("---------------------------------------"));
Serial.println(F("Concentration Units (standard)"));
Serial.print(F("PM 1.0: ")); Serial.print(data.pm10_standard);
Serial.print(F("\t\tPM 2.5: ")); Serial.print(data.pm25_standard);
Serial.print(F("\t\tPM 10: ")); Serial.println(data.pm100_standard);
Serial.println(F("Concentration Units (environmental)"));
Serial.print(F("PM 1.0: ")); Serial.print(data.pm10_env);
Serial.print(F("\t\tPM 2.5: ")); Serial.print(data.pm25_env);
Serial.print(F("\t\tPM 10: ")); Serial.println(data.pm100_env);
Serial.print(F("Particles > 0.3um / 0.1L air:")); Serial.println(data.particles_03um);
Serial.print(F("Particles > 0.5um / 0.1L air:")); Serial.println(data.particles_05um);
Serial.print(F("Particles > 1.0um / 0.1L air:")); Serial.println(data.particles_10um);
Serial.print(F("Particles > 2.5um / 0.1L air:")); Serial.println(data.particles_25um);
Serial.print(F("Particles > 5.0um / 0.1L air:")); Serial.println(data.particles_50um);
Serial.print(F("Particles > 10 um / 0.1L air:")); Serial.println(data.particles_100um);
