How do I autmoate a virtual pin to trigger?
Hi!
I’ve done many projects with Blynk in its various stages.
What I’m trying now is to create a basic automation run by Blynk: turn on and off a Virtual pin based on time.
Apparently this is not supported / I don’t find it.
I correctly control a device via web page (or mobile) but when I try to make a specific automation I read “you have no devices available to use in automation”
It used to be so easier back in the days.
I’d suggest you read the documentation, paying special attention to the way in which datastreams are enabled for use with automations in the template setup…
