Hye Dimitri,
For example, I have a room where temperature is being observe all the time, I also have a user based temperature that will become the pivot which will control servo motor that control the amount of air flow. Meaning, the servo motor will regulate the air flow automatically based on the temperature that the user desired. My question is, can I do through IoT, an option where the user can update his/her desired temperature online, without needing to change the data in the script?
Can Slider widget do the trick?
p/s If you have any threads that discuss about this, just point me them. I’ll figure out myself
