This is my first Blynk project, it is based on the Quickstart template on Free tier account. I can’t find anything on this.
I have a virtual switch on my phone that can activate a relay that supplies power to a light. It works fine, no issues. I’d like to add a physical monetary switch to the box that holds the ESP32 and relay module so someone without the app can turn the light off/on. Each press of the button would change the state of the light. I also want Blynk to know the state of the relay/light. If it was off and the button was pressed I want the light to come on and have the Blynk app on my phone show it is on.
How can I get a switch connected to a GPIO pin to ‘tell’ Blynk to (de)energize the relay? Can I simply control the pin directly with digitalWrite(relayPin,HIGH);
or will that “break” Blynk ?
What is the best way to test the GPIO pin to see if the button is pressed? Can I put an IF
to test the state of the GPIO to see if the button is pressed in ```void loop()```` or do I need an ISR.
Here is my sketch, any suggestions are welcome:
This is a simple demo of sending and receiving some data.
Be sure to check out other examples!
#define BLYNK_TEMPLATE_ID "***"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "***"
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
char ssid[] = "***";
char pass[] = "***";
const int ledPin =33;//32;
const int relayPin =26;//32;
// This function is called every time the Virtual Pin 0 state changes
BLYNK_WRITE(V0)
// Set incoming value from pin V0 to a variable
int value = param.asInt();
// Update state
Blynk.virtualWrite(V1, value);
BLYNK_WRITE(V4) // Executes when the value of virtual pin 0 changes
if(param.asInt() == 1)
// execute this code if the switch widget is now ON
digitalWrite(ledPin,HIGH); // Set digital pin 2 HIGH
Serial.println("HIGH!");
// execute this code if the switch widget is now OFF
digitalWrite(ledPin,LOW); // Set digital pin 2 LOW
digitalWrite(relayPin,LOW);
Serial.println("low!");
// This function is called every time the device is connected to the Blynk.Cloud
BLYNK_CONNECTED()
// Change Web Link Button message to "Congratulations!"
Blynk.setProperty(V3, "offImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations.png");
Blynk.setProperty(V3, "onImageUrl", "https://static-image.nyc3.cdn.digitaloceanspaces.com/general/fte/congratulations_pressed.png");
Blynk.setProperty(V3, "url", "https://docs.blynk.io/en/getting-started/what-do-i-need-to-blynk/how-quickstart-device-was-made");
Blynk.syncVirtual(V4); // will cause BLYNK_WRITE(V4) to be executed
// This function sends Arduino's uptime every second to Virtual Pin 2.
void myTimerEvent()
Blynk.virtualWrite(V2, millis() / 1000);
//Blynk.begin(auth, ssid, pass, "blynk.cloud", 80);
pinMode(ledPin, OUTPUT);
pinMode(relayPin, OUTPUT);
// to avoid delay() function!
