Continuing the discussion from How can I run BLYNK_WRITE in a loop?:
Before creating the topic
- Search forum for similar topics
 - Check http://docs.blynk.cc and http://help.blynk.cc/
 - Add details :
• Blynk Library version
• Add your sketch code.
Code should be formatted as example below.
#include "MAX30100_PulseOximeter.h"
#define REPORTING_PERIOD_MS     100
SoftwareSerial portTwo(15, 13); //TX,RX
char auth[] = "zfdfML-j0uRZGO2OZMI5H87B1vUS1zSD";    // You should get Auth Token in the Blynk App.
char ssid[] = "Ajay_Home";                       // Your WiFi credentials.
char pass[] = "Alph@##1307";
PulseOximeter pox;
uint32_t tsLastReport = 0;
int SpO2 = 0;
int bt_status ;
char sbuffer[30], ch;
unsigned char pos;
int read1 = 0;
int read2 = 0;
int read3 = 0;
int pinValue ;
//BLYNK_CONNECTED() {
//  //get data stored in virtual pin V0 from server
//  Blynk.syncVirtual(V6);
BLYNK_WRITE(V6)
  int pinValue = param.asInt();
  Serial.println(pinValue);
char mygetchar(void)
  while (!portTwo.available());
  return portTwo.read();
void onBeatDetected()
  Serial.println("Beat!");
void Spo2(void) {
  pox.update();
  SpO2 = pox.getSpO2();
  if (millis() - tsLastReport > REPORTING_PERIOD_MS) {
    Serial.print("SpO2:");
    Serial.print(SpO2);
    Serial.print("%");
    Serial.println();
    Blynk.virtualWrite(V4, SpO2);
    tsLastReport = millis();
void Blood(void) {
  ch = mygetchar();
  if (ch == 0x0A)
    pos = 0; // buffer position reset for next reading
    read1 = ((sbuffer[1] - '0') * 100) + ((sbuffer[2] - '0') * 10) + (sbuffer[3] - '0');
    read2 = ((sbuffer[6] - '0') * 100) + ((sbuffer[7] - '0') * 10) + (sbuffer[8] - '0');
    read3 = ((sbuffer[11] - '0') * 100) + ((sbuffer[12] - '0') * 10) + (sbuffer[13] - '0');
    Serial.println("*****************");
    Serial.print("SYSTOLIC:");
    Serial.print(read1);
    Serial.print('\n');
    Serial.print("DYSTOLIC:");
    Serial.print(read2);
    Serial.print('\n');
    Serial.print("PULSE");
    Serial.print(read3);
    Serial.print('\n');
    Blynk.virtualWrite(V1, read1);
    Blynk.virtualWrite(V2, read2);
    Blynk.virtualWrite(V3, read2);
  else { //store serial data to buffer
    sbuffer[pos] = ch;
    pos++;
void Both_sens(void) {
  if (pinValue == 0) {
    Spo2();
  else {
    Blood();
  portTwo.begin(9600);
  if (!pox.begin()) {
    Serial.println("FAILED");
    for (;;);
    Serial.println("SUCCESS");
  pox.setIRLedCurrent(MAX30100_LED_CURR_7_6MA);
  pox.setOnBeatDetectedCallback(onBeatDetected);
  //  timer.setInterval(1000, Blood);
    timer.setInterval(10, Both_sens);
hello there I am working a project I wanted to switch between two functions. in the above code I used button widget for switching but it executing once only … see the above “’'Both_sens” function it excuites once when I dump the code to esp , and I even tried Blynk.syncVirtual(); it was showing correct status of the button but in both_sens function if and else condition not working … please help me with this
