I literally just got this from the library but i keep getting an error "‘class BlynkConsole’ has no member named ‘begin’
BlynkConsole edgentConsole;
void console_init()
#ifdef BLYNK_PRINT
edgentConsole.begin(BLYNK_PRINT);
#endif
edgentConsole.print("\n>");
edgentConsole.addCommand("reboot", []() {
edgentConsole.print(R"json({"status":"OK","msg":"rebooting wifi module"})json" "\n");
delay(100);
restartMCU();
edgentConsole.addCommand("config", [](int argc, const char** argv) {
if (argc < 1 || 0 == strcmp(argv[0], "start")) {
BlynkState::set(MODE_WAIT_CONFIG);
} else if (0 == strcmp(argv[0], "erase")) {
BlynkState::set(MODE_RESET_CONFIG);
edgentConsole.addCommand("devinfo", []() {
edgentConsole.printf(
R"json({"name":"%s","board":"%s","tmpl_id":"%s","fw_type":"%s","fw_ver":"%s"})json" "\n",
getWiFiName().c_str(),
BLYNK_TEMPLATE_NAME,
BLYNK_TEMPLATE_ID,
BLYNK_FIRMWARE_TYPE,
BLYNK_FIRMWARE_VERSION
edgentConsole.addCommand("connect", [](int argc, const char** argv) {
if (argc < 2) {
edgentConsole.print(R"json({"status":"error","msg":"invalid arguments. expected: <auth> <ssid> <pass>"})json" "\n");
return;
String auth = argv[0];
String ssid = argv[1];
String pass = (argc >= 3) ? argv[2] : "";
if (auth.length() != 32) {
edgentConsole.print(R"json({"status":"error","msg":"invalid token size"})json" "\n");
return;
edgentConsole.print(R"json({"status":"OK","msg":"trying to connect..."})json" "\n");
configStore = configDefault;
CopyString(ssid, configStore.wifiSSID);
CopyString(pass, configStore.wifiPass);
CopyString(auth, configStore.cloudToken);
BlynkState::set(MODE_SWITCH_TO_STA);
edgentConsole.addCommand("wifi", [](int argc, const char* argv[]) {
if (argc < 1 || 0 == strcmp(argv[0], "show")) {
"mac:%s ip:%s (%s [%s] %ddBm)\n",
getWiFiMacAddress().c_str(),
WiFi.localIP().toString().c_str(),
getWiFiNetworkSSID().c_str(),
getWiFiNetworkBSSID().c_str(),
WiFi.RSSI()
} else if (0 == strcmp(argv[0], "scan")) {
int found = WiFi.scanNetworks();
for (int i = 0; i < found; i++) {
bool current = (WiFi.SSID(i) == WiFi.SSID());
"%s %s [%s] %s ch:%d rssi:%d\n",
(current ? "*" : " "), WiFi.SSID(i).c_str(),
macToString(WiFi.BSSID(i)).c_str(),
wifiSecToStr(WiFi.encryptionType(i)),
WiFi.channel(i), WiFi.RSSI(i)
WiFi.scanDelete();
edgentConsole.addCommand("firmware", [](int argc, const char** argv) {
if (argc < 1 || 0 == strcmp(argv[0], "info")) {
unsigned sketchSize = ESP.getSketchSize();
unsigned partSize = sketchSize + ESP.getFreeSketchSpace();
edgentConsole.printf(" Version: %s (build %s)\n", BLYNK_FIRMWARE_VERSION, __DATE__ " " __TIME__);
edgentConsole.printf(" Type: %s\n", BLYNK_FIRMWARE_TYPE);
edgentConsole.printf(" Platform: %s\n", BLYNK_INFO_DEVICE);
edgentConsole.printf(" SDK: %s\n", ESP.getSdkVersion());
edgentConsole.printf(" ESP Core: %s\n", ESP.getCoreVersion().c_str());
edgentConsole.printf(" App size: %dK (%d%%)\n", sketchSize/1024, (sketchSize*100)/partSize);
edgentConsole.printf(" App MD5: %s\n", ESP.getSketchMD5().c_str());
edgentConsole.addCommand("status", [](int argc, const char** argv) {
const uint64_t t = micros64() / 1000000;
unsigned secs = t % BLYNK_SECS_PER_MIN;
unsigned mins = (t / BLYNK_SECS_PER_MIN) % BLYNK_SECS_PER_MIN;
unsigned hrs = (t % BLYNK_SECS_PER_DAY) / BLYNK_SECS_PER_HOUR;
unsigned days = t / BLYNK_SECS_PER_DAY;
uint32_t heap_free; uint16_t heap_max;
uint8_t heap_frag;
ESP.getHeapStats(&heap_free, &heap_max, &heap_frag);
edgentConsole.printf(" Uptime: %dd %dh %dm %ds\n", days, hrs, mins, secs);
edgentConsole.printf(" Reset reason: %s\n", ESP.getResetReason().c_str());
edgentConsole.printf(" Flash: %dK\n", ESP.getFlashChipSize() / 1024);
edgentConsole.printf(" Stack unused: %d\n", ESP.getFreeContStack());
edgentConsole.printf(" Heap free: %d / %d\n", heap_free, heap_max);
edgentConsole.printf(" fragment: %d\n", heap_frag);
edgentConsole.printf(" max alloc: %d\n", ESP.getMaxFreeBlockSize());
#ifdef BLYNK_FS
FSInfo fs_info;
BLYNK_FS.info(fs_info);
edgentConsole.printf(" FS free: %d / %d\n", (fs_info.totalBytes-fs_info.usedBytes), fs_info.totalBytes);
#endif
#ifdef BLYNK_FS
edgentConsole.addCommand("ls", [](int argc, const char** argv) {
const char* path = (argc < 1) ? "/" : argv[0];
Dir dir = BLYNK_FS.openDir(path);
while (dir.next()) {
File f = dir.openFile(BLYNK_FILE_READ);
MD5Builder md5;
md5.begin();
md5.addStream(f, f.size());
md5.calculate();
String md5str = md5.toString();
edgentConsole.printf("%8d %-24s %s\n",
f.size(), dir.fileName().c_str(),
md5str.substring(0,8).c_str());
edgentConsole.addCommand("rm", [](int argc, const char** argv) {
if (argc < 1) return;
for (int i=0; i<argc; i++) {
const char* fn = argv[i];
if (BLYNK_FS.remove(fn)) {
edgentConsole.printf("Removed %s\n", fn);
edgentConsole.printf("Removing %s failed\n", fn);
edgentConsole.addCommand("mv", [](int argc, const char** argv) {
if (argc != 2) return;
if (!BLYNK_FS.rename(argv[0], argv[1])) {
edgentConsole.print("Rename failed\n");
edgentConsole.addCommand("cat", [](int argc, const char** argv) {
if (argc != 1) return;
if (!BLYNK_FS.exists(argv[0])) {
edgentConsole.print("File not found\n");
return;
if (File f = BLYNK_FS.open(argv[0], BLYNK_FILE_READ)) {
while (f.available()) {
edgentConsole.print((char)f.read());
edgentConsole.print("\n");
edgentConsole.print("Cannot open file\n");
edgentConsole.addCommand("echo", [](int argc, const char** argv) {
if (File f = BLYNK_FS.open(argv[1], BLYNK_FILE_WRITE)) {
if (!f.print(argv[0])) {
edgentConsole.print("Cannot write file\n");
#endif
BLYNK_WRITE(InternalPinDBG) {
String cmd = String(param.asStr()) + "\n";
edgentConsole.runCommand((char*)cmd.c_str());
