Need a virtual pin for get the value in Blynk LCD widget. Please help me if you can. ////////////
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,10,11,12,13); /// This is arduino UNO pin, you have to used your ESP8266 pin.
// WidgetLCD lcd(V1); // I've tried by this widget, It's not working.
char auth [] = "FYulGNNZxphnCh-KDnhJ";
char ssid [] = "Link3. 2";
char pass [] = "112uu34455";
int num_Measure = 128 ; // Set the number of measurements
int pinSignal = A0; // pin connected to pin O module sound sensor
int redLed = 5;
long Sound_signal; // Store the value read Sound Sensor
long sum = 0 ; // Store the total value of n measurements
long level = 0 ; // Store the average value
int soundlow = 40;
int soundmedium = 500;
void setup ()
pinMode (pinSignal, INPUT); // Set the signal pin as input
Serial.begin (9600);
lcd.begin(16,2);
void loop ()
// Performs 128 signal readings
for ( int i = 0 ; i <num_Measure; i ++)
Sound_signal = analogRead (pinSignal);
sum =sum + Sound_signal;
level = sum / num_Measure; // Calculate the average value
Serial.print("Sound Level: ");
lcd.print("Sound Level= ");
Serial.println (level-33);
lcd.print(level-33);
{if(level-33<soundlow)
lcd.setCursor(0,2);
lcd.print("Intensity= Low");
digitalWrite(redLed,LOW);
if(level-33>soundlow && level-33<soundmedium)
lcd.setCursor(0,2);
lcd.print("Intensity=Medium");
if(level-33>soundmedium)
lcd.setCursor(0,2);
lcd.print("Intensity= High");
digitalWrite(redLed,HIGH);
sum = 0 ; // Reset the sum of the measurement values
delay(200);
lcd.clear();
OUTPUT:
//////////////// Sound Level: 250 ///////////////////////////////
//////////////// Intensity: Medium //////////////////////////////
@Hiron_Bappy please edit your post, using the pencil icon at the bottom, and add triple backticks at the beginning and end of your code so that it displays correctly.
The first thing that YOU need to do is read this, restructure your code so that you have a clean void loop and a timer to call your new function that will take sound level readings and display them:
Once you’ve done this then post your updated code (correctly formatted of course). We can’t do this for you, because we don’t have your hardware to test the re-formatted code.
int redLed = 5;
int soundlow = 40;
void setup ()
timer.setInterval(1000L, sensorDataSend);
lcd.begin(16,2);
void sensorDataSend()
sensorvalue = analogRead (pinSignal);
Blynk.virtualWrite(V1, sensorValue);
lcd.setCursor(0,2);
lcd.setCursor(0,2);
lcd.setCursor(0,2);
delay(200);
void loop ()
lcd.clear();
No,
Please read at first, I’m new Blynk User, I’ve used this code in my ESP8266 for get the result in LCD,
My display showing me data well, Now willing to show the data in Blynk APPS,
LiquidCrystal lcd(16,2,14,12,13,15);
int redLed = 5;
int soundlow = 40;
void setup ()
lcd.begin(16,2);
void loop ()
lcd.setCursor(0,2);
lcd.setCursor(0,2);
lcd.setCursor(0,2);
delay(200);
lcd.clear();
In that case I need to know how to apply Blynk code on this code. May be I have to use virtual PIN, Now let me know where I’ll used the virtual pin for get the value. Please help me.
You had restructured your code to use a timer to call a function which takes your sound readings and displays them locally.
In my opinion you went further than I would have liked, because you added-in a:
to this function, which wasn’t what I suggested for you to do in the initial restructuring phase.
You also left behind an lcd.clear command in your void loop, but you wouldn’t say why.
Now you appear to have reverted to your original code, which is incompatible with Blynk because it has too much in your void loop.
Re-read my first post, and re-visit your second code.
