hello Every one
I am asking if how can manually switch on/off the PiR
I want it send me notification only when I switch the virtual LED on
this may code
WidgetLED led8_pir(V20);
void PRCS() // function
pir=1-(digitalRead(49));
if ((pir == LOW )&&( V20==HIGH))
Blynk.notify("Movement Detected!");
BLYNK_WRITE(V21) {
if (param.asInt()) {
@bernd331
Could you explain what you mean by “ESP8266 disturbs PIRs and generates false detections”? Is there some sort of RF or electrical interference going on?
I have seen that if I connect a PIR HS-SR501 to an ESP8266 I get false positives from the PIR.
The Internet says that the 2.4GHz interferences with the PIR-Sensor. There are a lot of tips out in the internet what to do to supress the false positives.But I have seen that in long term the fals positives always exists. In best case I got 2 or 3 false positives per hour. This best case was when I supplied the PIR with a seperate power supply and put the PIR in a metal box.
If somebody find’s a solution please let me knew
Assuming you want to be able to set a switch on the dashboard to determine when you get notified of motion from the PIR, you could do something like this: (this is a code fragment, of course, and not tested in any way)
#define LED V0
#define SWITCH V1
#define STATUS_DELAY 2000L // 2 seconds in msec
#define PIR_PIN 2 // Uno or Mega interrupt-enabled GPIO pin
WidgetLED Indicator(LED);
bool enabled = false;
volatile bool motion = false;
bool sendUpdate = false;
// configure dashboard button V1 as a SWITCH
BLYNK_WRITE (SWITCH) {
enabled = param.asInt();
void motionDetected ( void ) {
motion = true;
// only send notifications at specified intervals to avoid flood errors
void sendNotify ( void ) {
if ( sendUpdate ) {
Blynk.notify("Motion detected");
sendUpdate = false;
void setup ( void ) {
attachInterrupt(digitalPinToInterrupt(PIR_PIN), motionDetected, RISING);
timer.setInterval(STATUS_DELAY, sendNotify);
Indicator.off();
void loop ( void ) {
if ( enabled ) {
if ( motion ) {
// switch on the dashboard LED, set the flag to get a notification on next timer cycle, and reset motion flag
Indicator.on();
motion = false;
sendUpdate = true;
Indicator.off();
@Rom3oDelta7
Thank you for sharing this code, I am using this code on esp8266. But the problem is when I enable the SWITCH i get push notification straight away even though there is no movement and its keep coming in every two second as STATUS_DELAY.I just want to get the notification only if there is any motion detected. What should I add to get this ?? TIA
Which parts of “untested code fragment” (not to mention a not particularly well devised and messy loop) and date code indicating the rather old age of this topic are confusing
@coz773… if you have actual Blynk code of your own that you need some advice with, I recommend you create a newer relevant topic, show what you have and what you have tried… and go into this looking for guidance, not some magic solution for what is essentially a logic if else() question, not a distinctly searchable “fix”
