Hallo,
I have a problem with the integration of this code.
What am I doing wrong?
#include <DHT.h>
int Thermostat = D1;
char auth[] = "xxxxxxxx";
char ssid[] = "xxxxxxxxxxxxx";
char pass[] = "xxxxxxxxxxxxxx";
#define DHTPIN 2 // What digital pin we're connected to
#define DHTTYPE DHT22 // DHT 11
//#define DHTTYPE DHT22 // DHT 22, AM2302, AM2321
//#define DHTTYPE DHT21 // DHT 21, AM2301
DHT dht(DHTPIN, DHTTYPE);
float readData = DHT.read22(dataPin); // Reads the data from the sensor
float p = DHT.temperature; // Gets the values of the temperature
float k = DHT.humidity; // Gets the values of the humidity
int pinValue2;
BLYNK_WRITE(V4) // V4 is the number of Virtual Pin
{pinValue2 = param.asInt();}
if (p > pinValue2){digitalWrite(Thermostat, LOW);}
else {digitalWrite(Thermostat, HIGH);}
pinMode(Thermostat, OUTPUT);
intelligenter_Thermostat:34: error: expected primary-expression before '.' token
intelligenter_Thermostat:34: error: 'dataPin' was not declared in this scope
intelligenter_Thermostat:35: error: expected primary-expression before '.' token
intelligenter_Thermostat:36: error: expected primary-expression before '.' token
intelligenter_Thermostat:40: error: expected unqualified-id before '{' token
Znaleziono wiele bibliotek w "BlynkSimpleEsp8266.h"
Wykorzystane: C:\Users\piotrsu\Documents\Arduino\libraries\tools
Niewykorzystane: C:\Users\piotrsu\Documents\Arduino\libraries\libraries
Niewykorzystane: C:\Users\piotrsu\Documents\Arduino\libraries\Blynk
Niewykorzystane: D:\Arduino\libraries\tools
Niewykorzystane: D:\Arduino\libraries\libraries
Niewykorzystane: D:\Arduino\libraries\Blynk
Znaleziono wiele bibliotek w "BlynkApiArduino.h"
Wykorzystane: C:\Users\piotrsu\Documents\Arduino\libraries\Blynk
exit status 1
Niewykorzystane means not used.
Wykorzystane means used.
