i want to Display the Value of my zeRGBa on my Terminal. The zeRGBa is on SPLIT mode. I wrote this code but it obviously doesn’t work. Can you guys help me to correct my code? You can see my code below.
Thanks!
char auth[] = "0";
char ssid[] = "0";
char pass[] = "0";
int r;
int g;
int b;
WidgetTerminal terminal(V1);
BLYNK_WRITE(D0) {
r = param.asInt();
BLYNK_WRITE(D1) {
g = param.asInt();
BLYNK_WRITE(D3) {
b = param.asInt();
terminal.flush();
terminal.print(String(r));
Remove these from the void loop(); and put them in a timed function of it’s own if you need…
Besides, you don’t have any code to take the individual values and combine them into a string to display anyhow… That stuff is programming 101, not Blynk specific.
But you could simply send the colour channels value directly to the terminal in each properly assigned BLYNK_WRITE(vPin) function.
The terminal wiget can also work with a Blynk.virtualWrite(vPin, value) command.
BLYNK_WRITE(vPin) { // Use virtual pin assigned to RED channel on the zeRGBa
r = param.asInt(); // Get value from zeRGBa widget
Blynk.virtualWrite(V1, r) // Print value to Terminal
