i am facing many errors while writing code for nodemcu on arduino ide i need help! i want to make drone reciver with nodemcu esp8266 and blynk app transmitter.
Posting your whole sketch might help.
Okay.
#include <Servo.h>
#define BLYNK_AUTH_TOKEN "2T-Iv5jVEBwrvW7zfwLkFnXnyspPSD3W" //Enter your blynk auth token
char ssid[] = "--0----";//Enter your WIFI name
char pass[] = "---------";//Enter your WIFI password
Servo motor1;
Servo motor2;
Servo motor3;
Servo motor4;
int motor1Speed = 0; // Speed of motor 1
int motor2Speed = 0; // Speed of motor 2
int motor3Speed = 0; // Speed of motor 3
int motor4Speed = 0; // Speed of motor 4
motor1.attach(D0);
motor2.attach(D1);
motor3.attach(D2);
motor4.attach(D4);
Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
BLYNK_WRITE(V1) {
motor1Speed = param[0].asInt();
motor1Speed = map(motor1Speed, 0, 1023, 1000, 2000);
motor1.writeMicroseconds(motor1Speed);
BLYNK_WRITE(V2) {
motor2Speed = param[0].asInt();
motor2Speed = map(motor2Speed, 0, 1023, 1000, 2000);
motor2.writeMicroseconds(motor2Speed);
BLYNK_WRITE(V3) {
motor3Speed = param[0].asInt();
motor3Speed = map(motor3Speed, 0, 1023, 1000, 2000);
motor3.writeMicroseconds(motor3Speed);
BLYNK_WRITE(V4) {
motor4Speed = param[0].asInt();
motor4Speed = map(motor4Speed, 0, 1023, 1000, 2000);
motor4.writeMicroseconds(motor4Speed);
“blynk-cloud.com” is the old blynk server. The new blynk server is"blynk.cloud".
Also, there’s no need to specify a server, just add the
#define BLYNK_TEMPLATE_ID "TMPLxxxxxx"
#define BLYNK_DEVICE_NAME "Device"
#define BLYNK_AUTH_TOKEN "YourAuthToken"
At the top of your sketch and use
Instead.
Are you aware that the Blynk app doesn’t talk directly to the NodeMCU?
The NodeMCU needs to connect to a WiFi signal so that it can talk to the Blynk server, and the phone running the Blynk also needs to talk to the Blynk server - either via WiFi or a mobile data network.
This means that your quadcopter needs to be in range of an internet connected WiFi network at all times.
yes i know .
can you help me with it
tried it but not working
Do you have the latest version of the blynk library installed (1.1.0)?
let me check.
Post your full code, and the serial monitor output when you run that code.
#include <Servo.h>
Servo motor1;
Servo motor2;
Servo motor3;
Servo motor4;
motor1.attach(D0);
motor2.attach(D1);
motor3.attach(D2);
motor4.attach(D4);
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
BLYNK_WRITE(V4) {
This is the full code and it is showing and the serial monitor is showing following-
��l���l$�H<XO�Y:z6b���H�l�h��lb<l�42h$��2dN
You should add this to the beginning of your void setup…
Serial.begin(74880);
and set your serial monitor to 74880 baud.
now it si showing
/___/ v1.1.0 on ESP8266
#StandWithUkraine https://bit.ly/swua
[9825] Connecting to blynk-cloud.com:80
[15843] Connecting to blynk-cloud.com:80
[21845] Connecting to blynk-cloud.com:80
[27850] Connecting to blynk-cloud.com:80
[33856] Connecting to blynk-cloud.com:80
Okay, well the code that you posted in post #12 doesn’t have the changes that @John93 told you to make in post #4 and which you said you’d tried.
it is showing same thing!
#include <Servo.h>
#define BLYNK_TEMPLATE_ID "TMPLWeZBiMUM"
#define BLYNK_DEVICE_NAME "UR Drone"
char ssid[] = "realme 5i";//Enter your WIFI name
char pass[] = "sambhavjain";//Enter your WIFI password
Servo motor1;
Servo motor2;
Servo motor3;
Servo motor4;
motor1.attach(D0);
motor2.attach(D1);
motor3.attach(D2);
motor4.attach(D4);
BLYNK_WRITE(V0) {
BLYNK_WRITE(V1) {
BLYNK_WRITE(V2) {
BLYNK_WRITE(V3) {
That’s because @John93 told you to…
but you chose to add these three lines of code further down your sketch instead.
