i am using arduino mega, 2 soil moisture sensor, 1 DHT11, relay, wifi shield and blynk…
this is my code… i am also searching for how to convert moisture sensor reading to percentage,…
#define BLYNK_PRINT Serial //declaration to use Blynk
#include <ESP8266_Lib.h>
#include <DHT.h>
#define DHTPIN 5 // Connect the signal pin of DHT11 sensor to digital pin 5
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
int sensor_pin = A0; //soil moisture sensor 1
int sensor1 = A1; //soil moisture sensor 2
int output_value ; //output value from soil moisture sensor 1
int sensor_value ; //output value from soil moisture sensor 2
int Pump=13;
char auth[] = " f79df2aeed1945bab751cf4df80f246b"; // Author Token from email
char ssid[] = "TKP Class Room";
char pass[] = "TkpH0lding";
#define EspSerial Serial
// Your ESP8266 baud rate:
#define ESP8266_BAUD 9600
ESP8266 wifi(&EspSerial);
void sendSensor()
output_value= analogRead(sensor_pin);
sensor_value= analogRead(sensor1);
float h = dht.readHumidity();
if (isnan(h) || isnan(t)) {
return;
Blynk.virtualWrite(V6, h);
Blynk.virtualWrite(V8, t);
Blynk.virtualWrite(V9, output_value);
Blynk.virtualWrite(V10, sensor_value);
//Blynk.virtualWrite(V7, output_value );
void myTimerEvent()
void pump(){
if(output_value>200||sensor_value>200){
digitalWrite(Pump,HIGH);
delay(100);
if(output_value<140||sensor_value<140){
digitalWrite(Pump,LOW);
delay(100);
dht.begin();
pinMode(Pump,OUTPUT);
// Set ESP8266 baud rate
pump();
sendSensor();
