#include <IRremote.h>
#include <AceButton.h>
using namespace ace_button;
BlynkTimer timer1;
// Define the GPIO connected with Relays
#define RelayPin1 D0 //D0
#define RelayPin2 D1 //D1
#define RelayPin3 D2 //D2
#define RelayPin4 D3 //D3
//Define the GPIO connected with Switches
#define SwitchPin1 D5 //D5
#define SwitchPin2 D6 //D6
#define SwitchPin3 1 //TX
#define SwitchPin4 3 //RX
//Define the GPIO shows Wi-Fi led & IR reciver pin
#define wifiLed D4 //D4
#define IR_RECV_PIN D5 //D5
#define VPIN_BUTTON_1 V1
#define VPIN_BUTTON_2 V2
#define VPIN_BUTTON_3 V3
#define VPIN_BUTTON_4 V4
#define VPIN_BUTTON_5 V5
#define VPIN_BUTTON_6 V6
int toggleState_1 = 1; //Define integer to remember the toggle state for relay 1
int toggleState_2 = 1; //Define integer to remember the toggle state for relay 2
int toggleState_3 = 1; //Define integer to remember the toggle state for relay 3
int toggleState_4 = 1; //Define integer to remember the toggle state for relay 4
int wifiFlag = 0;
IRrecv irrecv(IR_RECV_PIN);
decode_results results;
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
AceButton button3(&config3);
ButtonConfig config4;
AceButton button4(&config4);
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
void handleEvent3(AceButton*, uint8_t, uint8_t);
void handleEvent4(AceButton*, uint8_t, uint8_t);
#define AUTH âZAVXEL4JM6n2K5X53N_t3FIILjmbOZUHâ // You should get Auth Token in the Blynk App.
#define WIFI_SSID âashwaniâ //Enter Wifi Name
#define WIFI_PASS â12340644â //Enter wifi Password
void relayOnOff(int relay){
switch(relay){
case 1:
if(toggleState_1 == 1){
digitalWrite(RelayPin1, LOW); // turn on relay 1
toggleState_1 = 0;
Serial.println("Device1 ON");
else{
digitalWrite(RelayPin1, HIGH); // turn off relay 1
toggleState_1 = 1;
Serial.println("Device1 OFF");
delay(100);
break;
case 2:
if(toggleState_2 == 1){
digitalWrite(RelayPin2, LOW); // turn on relay 2
toggleState_2 = 0;
Serial.println("Device2 ON");
else{
digitalWrite(RelayPin2, HIGH); // turn off relay 2
toggleState_2 = 1;
Serial.println("Device2 OFF");
delay(100);
break;
case 3:
if(toggleState_3 == 1){
digitalWrite(RelayPin3, LOW); // turn on relay 3
toggleState_3 = 0;
Serial.println("Device3 ON");
else{
digitalWrite(RelayPin3, HIGH); // turn off relay 3
toggleState_3 = 1;
Serial.println("Device3 OFF");
delay(100);
break;
case 4:
if(toggleState_4 == 1){
digitalWrite(RelayPin4, LOW); // turn on relay 4
toggleState_4 = 0;
Serial.println("Device4 ON");
else{
digitalWrite(RelayPin4, HIGH); // turn off relay 4
toggleState_4 = 1;
Serial.println("Device4 OFF");
delay(100);
break;
default : break;
void all_SwitchOff(){
toggleState_1 = 1; digitalWrite(RelayPin1, toggleState_1); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); delay(100);
toggleState_2 = 1; digitalWrite(RelayPin2, toggleState_2); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); delay(100);
toggleState_3 = 1; digitalWrite(RelayPin3, toggleState_3); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); delay(100);
toggleState_4 = 1; digitalWrite(RelayPin4, toggleState_4); Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4); delay(100);
void all_SwitchOn(){
toggleState_1 = 0; digitalWrite(RelayPin1, toggleState_1); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); delay(100);
toggleState_2 = 0; digitalWrite(RelayPin2, toggleState_2); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); delay(100);
toggleState_3 = 0; digitalWrite(RelayPin3, toggleState_3); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); delay(100);
toggleState_4 = 0; digitalWrite(RelayPin4, toggleState_4); Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4); delay(100);
void ir_remote(){
if (irrecv.decode(&results)) {
switch(results.value){
case 0x----------: relayOnOff(1); Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); break;
case 0x----------: relayOnOff(2); Blynk.virtualWrite(VPIN_BUTTON_2, toggleState_2); break;
case 0x----------: relayOnOff(3); Blynk.virtualWrite(VPIN_BUTTON_3, toggleState_3); break;
case 0x---------: relayOnOff(4); Blynk.virtualWrite(VPIN_BUTTON_4, toggleState_4); break;
case 0x---------: all_SwitchOn(); break;
case 0x---------: all_SwitchOff(); break;
default : break;
//Serial.println(results.value, HEX);
irrecv.resume();
// When App button is pushed - switch the state
BLYNK_WRITE(VPIN_BUTTON_1) {
toggleState_1 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_2) {
toggleState_2 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_3) {
toggleState_3 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_4) {
toggleState_4 = param.asInt();
BLYNK_WRITE(VPIN_BUTTON_5) {
all_SwitchOff();
BLYNK_WRITE(VPIN_BUTTON_6) {
all_SwitchOn();
BLYNK_CONNECTED() {
Blynk.syncVirtual(VPIN_BUTTON_1);
Blynk.syncVirtual(VPIN_BUTTON_2);
Blynk.syncVirtual(VPIN_BUTTON_3);
Blynk.syncVirtual(VPIN_BUTTON_4);
void checkBlynkStatus() { // called every 3 seconds by SimpleTimer
bool isconnected = Blynk.connected();
if (isconnected == false) {
wifiFlag = 1;
digitalWrite(wifiLed, LOW); //Turn off WiFi LED
if (isconnected == true) {
wifiFlag = 0;
digitalWrite(wifiLed, HIGH); //Turn on WiFi LED
irrecv.enableIRIn(); // Start the receiver
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
pinMode(SwitchPin3, INPUT_PULLUP);
pinMode(SwitchPin4, INPUT_PULLUP);
//During Starting all Relays should TURN OFF
config1.setEventHandler(button1Handler);
config2.setEventHandler(button2Handler);
config3.setEventHandler(button3Handler);
config4.setEventHandler(button4Handler);
button1.init(SwitchPin1);
button2.init(SwitchPin2);
button3.init(SwitchPin3);
button4.init(SwitchPin4);
WiFi.begin(WIFI_SSID, WIFI_PASS);
timer1.setInterval(2000L, checkBlynkStatus); // check if Blynk server is connected every 3 seconds
Blynk.config(AUTH);
ir_remote();
button1.check();
button2.check();
button3.check();
button4.check();
if (WiFi.status() == WL_CONNECTED)
timer1.run(); // Initiates SimpleTimer
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println(âEVENT1â);
switch (eventType) {
case AceButton::kEventPressed:
Serial.println(âkEventPressedâ);
toggleState_1 = 0;
Blynk.virtualWrite(VPIN_BUTTON_1, toggleState_1); // Update Button Widget
break;
case AceButton::kEventReleased:
Serial.println(âkEventReleasedâ);
toggleState_1 = 1;
break;
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println(âEVENT2â);
toggleState_2 = 0;
break;
toggleState_2 = 1;
break;
void button3Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println(âEVENT3â);
toggleState_3 = 0;
break;
toggleState_3 = 1;
break;
void button4Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println(âEVENT4â);
toggleState_4 = 0;
break;
toggleState_4 = 1;
break;
//While compiling I got an error. /data/data/name.antonsmirnov.android.arduinodroid2/sdkEsp8266/hardware/esp8266/2.7.1/tools/sdk/include/ipv4_addr.h:53:22: error: field âipâ has incomplete type âip4_addrâ
The error is mentioned above Please help me i am new.
