Hey guys,
so i am working on a home automation project which lets you control light from the blynk app as well as manually and the state of the switch is shown in the app. I have got everything working but am having an issue with the switch as the switch is reversed everytime i use the app. For example i turn on the light using the switch the light turns on and the switch remains on and then i switch off the light using the phone but when i turn the switch off the light turns back on again. i have attached the code below so that you can take a look and help me fix the switch.
BlynkTimer timer; //Make a simple timer
void checkSwitch();
int relayState = LOW;
int switchState = HIGH;
char auth[] = "BxVoOl0SiO3BHhHXvJt9SWd1bxNhO3YD";
char ssid[] = "D-Link_DIR-600M";
char pass[] = "Aventador";
#define RELAY_PIN 5 //D1
#define SWITCH 2 //D4
#define VPIN V2
BLYNK_CONNECTED()
Blynk.syncVirtual(VPIN); //Syncing state from server
BLYNK_WRITE(VPIN)
relayState = param.asInt();
digitalWrite(RELAY_PIN, relayState); //When app button is used reflect the state
void checkSwitch()
if (digitalRead(SWITCH) == LOW)
if (switchState != LOW)
relayState = !relayState;
digitalWrite(RELAY_PIN, relayState); //Changing relay state
Blynk.virtualWrite(VPIN, relayState); //update widget in blynk
switchState = LOW;
else if (digitalRead(SWITCH) == HIGH)
if (switchState != HIGH)
switchState = HIGH;
pinMode(RELAY_PIN, OUTPUT);
pinMode(SWITCH, INPUT_PULLUP);
timer.setInterval(500L, checkSwitch);
