char auth[] = "d89adaa1a4f742b58ced23d605008047";
char ssid[] = "SmartAnSolver";
char pass[] = "admin123";
Unfortunately, we aren’t psychic, so without details of how your relay is connected to your NodeMCU, and whether it’s an active high or low relay, it’s impossible to do anything other than guess at what the problem is.
I realise that English may not be your first language, but you either have to make a better attempt at explaining your issues in a way that others can understand - possibly in your native language, or solve the problems yourself.
As it stands at the moment, your posts make you seem like a troll. If you aren’t, then you need to improve your communication on the forum if you want assistance.
const int Relay_1 = 16; //D0
const int Relay_2 = 5; //D1
const int Relay_3 = 4; //D2
const int Relay_4 = 0; //D3
const int Relay_5 = 2; //D4
const int Relay_6 = 14; //D5
const int Relay_7 = 12; //D6
const int Relay_8 = 13; //D7
const int Relay_9 = 15; //D8
pinMode(Relay_1, OUTPUT);
pinMode(Relay_2, OUTPUT);
pinMode(Relay_3, OUTPUT);
pinMode(Relay_4, OUTPUT);
pinMode(Relay_5, OUTPUT);
pinMode(Relay_6, OUTPUT);
pinMode(Relay_7, OUTPUT);
pinMode(Relay_8, OUTPUT);
pinMode(Relay_9, OUTPUT);
digitalWrite(Relay_1, HIGH);
digitalWrite(Relay_2, HIGH);
digitalWrite(Relay_3, HIGH);
digitalWrite(Relay_4, HIGH);
digitalWrite(Relay_5, HIGH);
digitalWrite(Relay_6, HIGH);
digitalWrite(Relay_7, HIGH);
digitalWrite(Relay_8, HIGH);
/********************** Relay 1 ON/OFF V1 *******************************/
BLYNK_WRITE(V1)
int pinValue = param.asInt();
if (pinValue == 1)
Serial.println("Relay 1 On");
else if (pinValue == 0)
digitalWrite(Relay_1, LOW);
Serial.println("Relay 1 Off");
/********************** Relay 2 ON/OFF V2 *******************************/
BLYNK_WRITE(V2)
if (pinValue == 1)
Serial.println("Relay 2 On");
digitalWrite(Relay_2, LOW);
Serial.println("Relay 2 Off");
/********************** Relay 3 ON/OFF V3 *******************************/
BLYNK_WRITE(V3)
if (pinValue == 1)
Serial.println("Relay 3 On");
digitalWrite(Relay_3, LOW);
Serial.println("Relay 3 Off");
/********************** Relay 4 ON/OFF V4 *******************************/
BLYNK_WRITE(V4)
if (pinValue == 1)
Serial.println("Relay 4 On");
digitalWrite(Relay_4, LOW);
Serial.println("Relay 4 Off");
/********************** Relay 5 ON/OFF V5 *******************************/
BLYNK_WRITE(V5)
if (pinValue == 1)
Serial.println("Relay 5 On");
digitalWrite(Relay_5, LOW);
Serial.println("Relay 5 Off");
/********************** Relay 6 ON/OFF V6 *******************************/
BLYNK_WRITE(V6)
if (pinValue == 1)
Serial.println("Relay 6 On");
digitalWrite(Relay_6, LOW);
Serial.println("Relay 6 Off");
/********************** Relay 7 ON/OFF V7 *******************************/
BLYNK_WRITE(V7)
if (pinValue == 1)
Serial.println("Relay 7 On");
digitalWrite(Relay_7, LOW);
Serial.println("Relay 7 Off");
/********************** Relay 8 ON/OFF V8 *******************************/
BLYNK_WRITE(V8)
if (pinValue == 1)
Serial.println("Relay 8 On");
digitalWrite(Relay_8, LOW);
Serial.println("Relay 8 Off");
yes because at start, nodemcu pin are LOW
and your relay board need HIGH to have relay off
so , at start I always put all relays pins HIGH.
ok sorry
ok thanku
bundle of thanks <3
can we make a web portal to use on desktop just like blynk app ?
a little correction
not all Relays need High to be OFF
I got modules with high level trigger ( active high )
as an example: 4 relay module high/low level trigger
https://s3-ap-southeast-1.amazonaws.com/a2.datacaciques.com/wm/307176851/3849027817/2766353203.jpg
It depends what you’re doing with your relays, and whether you mind some of them being activated momentarily on startup.
I’d certainly avoid using GPIOs 0, 1, 15 & 16
This excellent topic is well worth a read:
Have any solution about the security or privacy forr this blynky app. ? Can we make diffirent privacy for diffirnet devices using in same project in blynk app?
Your App login is your key … there is no further segregation of devices. Although you could probably program various security measures that are required by the App user before they can control certain items… that is all up to your ingenuity and how well you can code though (button tap codes, terminal or Input widget PIN codes, “hidden” buttons in distant tabs, etc.)
This was just an example
help me please… when i upload sketch in my nodemu, it works well but when cut off power supply, it not work, mean code not upload permanently, just as flash
I don’t see how that’s possible… if you upload, and the code works at least once, then it is properly flashed into the MCU memory. Perhaps you need to ask on the esspressif site.
ok, i try to ask on their site. thanks
since flash memory is non-volatile, that make no sense
but i worked on other projects with other codes on same nodemcu… it works well
What’s probably happening is that you’ve uploaded code, or connected hardware, to your NodeMCU that’s causing it to go into a reset loop.
If you look at the serial monitor with the correct baud rate selected (probably 74880) then you’ll see the boot messages from the device. Chances are that you’ll see WDT reset messages and if you google these (as opposed to posting them here) you’ll get a clue about what is happening.
