Hold button for a duration
I have a project where I need a button press held a little longer (i.e. 1-2 seconds) to ensure the relay triggers my door to open - anything shorter and the relay triggers, but it is too brief to trigger the door.
The current working code is below, and I have seen instances where timer.setTimeout is used but I donโ€™t understand how to use it in the below code:
BLYNK_WRITE(V0)
      int pinValue = param.asInt();
      if (pinValue == 5) {
            const byte RelayON[] = {0xA0, 0x01, 0x01, 0xA2};
            Serial.write(RelayON, sizeof(RelayON));
         }else {
            const byte RelayOFF[] = {0xA0, 0x01, 0x00, 0xA1};
            Serial.write(RelayOFF, sizeof(RelayOFF));
Look at the old fashioned debouncing code for buttons and try to adapt that
Are you using a segmented switch or a button?
I am curious as to why you use 5 instead of 1?
param.asInt == โ€˜5โ€™
Edit:
Either way, try this?:
BLYNK_WRITE(V0)
    timer.setTimeout(1500L, []() {
You will also need to declare:
And this in void loop()
Video_2019-05-13_181245 2019-05-13_183235
/**************** LOCK UNLOCK **************/
BLYNK_WRITE(V50) {  // button to be held down to activate
    if (param.asInt() and  !LongHold ) {
    ButtonTimer = timer.setTimeout(2000, LongHoldDetect); // press 2 sec
    ButtonPressed = true;
// Button has been released
    ButtonPressed = false;        // Reset press flag
    // If the long hold function wasn't called, it's a short press.
    if (!LongHold) {
      timer.deleteTimer(ButtonTimer);   // Kill the long hold timer if it hasn't been activated.
      // Reset the long press flag
      LongHold = false;
      greenLed.off();
      redLed.on();
// Checks for long press condition on SETTINGS button
void LongHoldDetect() {
  // If the button is still depressed, it's a long hold
  if (ButtonPressed) {
    LongHold = true;
    greenLed.on();
    redLed.off();
BLYNK_WRITE(V51) {  // Reset button
  if (param.asInt()) {
    if (LongHold = true) {
      LongHold =  false;
      greenLed.off();
      redLed.on();
