I was troubleshooting trying to get the BLE function to work with my board/HM-10 & kept getting “Packet Too Big” in the serial counsel and figured out the solution. It wasn’t in the Blynk library or the connections but the HM-10 bluetooth chip configuration. I noticed several posts about it on the forum and thought I would put my solution out there encase anyone else is struggling getting the BLE connection. These are the settings you need to set in order for the HM-10 to successfully talk with the board. Tested on a Sparkfun SAMD Dev board and a Arduino Mega 2560.
HM-10 Setup:
Firmware: HMSoft V704
Baud: 0-9600
Pin type: 0-Not need PIN code
Role: 0-Peripheral
Mode: 0-transmission mode
Module work type: 0-work immediately
Parity bit: 0-none
flow control: 0-off
Notify: 0-no notification
and the sketch:
#define BLYNK_PRINT SerialUSB // SAMD
#define BLYNK_DEBUG SerialUSB
//#define BLYNK_PRINT Serial // Mega
//#define BLYNK_DEBUG Serial
char auth[] = "token here";
SerialUSB.begin(9600); //SAMD board
//Serial.begin(9600); // Mega
Serial1.begin(9600);
Blynk.begin(Serial1, auth);
