Just for reference, I’m using the latest Blynk library, Ard IDE 1.6.9. and a Wemos D1 mini.
I don’t really know when it began but I started having some RTC widget issues- it just wasn’t working right. I heard someone on here say it could be the latest IDE (.11) that is the issue, so I downgraded to .9, used the basic RTC sketch and I’ve found two issues:
I’ve noticed this in my other code, but putting a ‘V’ in front of the virtual pin number- not just for the RTC widget- results in a compile error. This only happens for higher numbered pins… Not an issue if I put ‘V5’.
BLYNK_ATTACH_WIDGET(rtc, V105); << Not working with Blynk simple esp.
The rabbit hole goes further. The code DOES compile and upload if I get rid of the V, but if I use pin 105 for my RTC widget, the widget does NOT work correctly (doesn’t seem to be communicating the proper value to arduino). However, if I change to pin 5, or V5, the widget DOES work.
Any thoughts?
Edit: even deeper rabbit hole- RTC doesn’t work on pin 105, but I can assign it to V5, and send the correct hour to pin 106
