Vivek1
February 3, 2019, 1:24pm
1
Before creating the topic
Search forum for similar topics
Check http://docs.blynk.cc and http://help.blynk.cc/
Add details :
• Blynk Library version
• Add your sketch code. Code should be formatted as example below.
You’d be better editing your post and shortening your title then adding some meaningful text in the body of your post.
The supported hardware list here:
# Supported Hardware
Blynk supports more than 400 boards already, including support for Arduino, Particle, ARM mbed, TI Energia, MicroPython, Node.js, OpenWRT and many Single Board Computers. You can add your own connection types easily (see [these](https://github.com/blynkkk/blynk-library/tree/master/examples/More/ArduinoClient) examples for Arduino)!
## Platforms
- **Arduino** (https://github.com/blynkkk/blynk-library)
- Arduino MKR WiFi 1010
- Arduino MKR GSM 1400
- Arduino MKR NB 1500
- Arduino Uno, Duemilanove
- Arduino Nano, Mini, Pro Mini, Pro Micro, Due, Mega
- Arduino 101 (Intel Curie, with BLE)
- Arduino MKR1000
- Arduino Zero
- Arduino Yún (onboard WiFi and Ethernet, via Bridge)
- Arduino.org UNO WiFi
- Arduino MKR VIDOR 4000 (use the example for MKR WiFi 1010)
- Arduino UNO WiFi Rev.2 (use the example for MKR WiFi 1010)
This file has been truncated. show original
Includes:
Energia
Texas Instruments
CC3220SF-LaunchXL
CC3200-LaunchXL
Tiva C Connected LaunchPad
Stellaris LM4F120 LaunchPad
MSP430F5529 + CC3100
LaunchPad MSP432
RedBearLab (CC3200, WiFi Mini)
I’m not familiar with this hardware, so can’t say if this means that your particular board will work, but it seems like it’s worth a try.
