Hello. I have tried searching the internet for help but I am not knowledgeable at all in Arduino stuff, never mind in Blynk stuff! Here’s my issue:
I want to be able to tell Arduino UNO to run the void loop when the pinValue=1 i.e. when I push the virtual button on my phone. In order to do this, I tried writing in BLYNK_WRITE(V1) that when pinValue=1, it sets the value of a==1, and then runs the loop function. Inside my loop function, if a=1 then it does some stuff. I am connected through USB.
Here is the code I wrote for this:
#define BLYNK_PRINT SwSerial
#include <Servo.h>
#include <DFRobot_HX711.h>
int pinValue;
int servopin = 9;
int angle = 0;
int button = 3;
float poids = 0;
int i=0;
int a=0;
char auth[] = "HXoG4hYsPCq5GtVQ15kGnCuw9Q-Kkg2J";
DFRobot_HX711 scale(A2, A3);
Servo servo;
// in Blynk app writes values to the Virtual Pin V1
BLYNK_WRITE(V1)
Serial.print("V1 Slider value is: ");
Serial.println(pinValue);
if(param.asInt() == 1) {
a==1;
loop();
// process received value
SwSerial.begin(9600);
Blynk.begin(Serial, auth);
pinMode(button, INPUT_PULLUP);
servo.attach(servopin);
poids = scale.readWeight();
if ((a==1) and (poids<20)){
servo.write(angle);
if(angle == 0)
angle = 180;
if(angle == 180)
angle = 0;
Serial.print(poids);
Serial.println(" g");
Serial.println(" Gamelle vide. Je vais la remplir!");
else if (poids>20) {
while (i<1){
Serial.println(" Gamelle pleine");
i++;
My problem is in the BLYNK_WRITE(V1) part. I want my code to run the loop function when pinValue=1. But it doesn’t do anything. My project is connected, and everything seems to be OK, its just that when I push the button on the app, nothing happens. The code is supposed to make a servo turn when a load cell reads a weight of less than 20g, but this is not relevant to my problem, as this code runs perfectly with a digital button. So all I want to do is replace the physical button by a virtual one, but I can’t get it right.
Could someone help me figure out what’s wrong? Thank you so much in advance.
