Help with Troubleshooting Blynk Garage Door Monitor
Hi All,
This is my first post in this forum. I bought my dad an NodeMCU (ESP8266) for Christmas last year so he can mess around with learning C++ and microcontrollers. He has a long history with programming back to the beginning of computers, but hasn’t touched it in a few decades.
His first project was to use a NodeMCU to read the open/close state of two garage doors and write the state with a timestamp to Blynk. We got this working months ago.
He recently decided he wanted to add temperature and humidity sensing to the code as well. We selected a SHT31-D temperature sensor breakout board from Adafruit (https://www.adafruit.com/product/2857). Using their sample code, he was able to read temp and humidity over I2C successfully and print it to the serial port.
He ran into a wall when he tried to merge the two pieces of code. For some reason, the merged code crashes the NodeMCU whenever it tries to read the temp or humidity. This did not happen with Adafruit’s sample code.
Is there some reason a NodeMCU/ESP8266 cannot communicate with Blynk at the same time as communicating over I2C? Why would this crash the NodeMCU?
Edit: Trying to figure out how to attach my code
Please excuse if the code is a bit messy. I am trying to let him figure out the troubleshooting on his own.
Appreciate any feedback you can provide!
Here is the original garage door program that has been running fine for months.
// Plug Micro USB into NodeMCU
// To upload program:  Need to connect Pin D3 (FLash / GPIO0) to GND. Disconnect after upload.
// May need to press RST to run program after upload
#include <TimeLib.h>
#include <WidgetRTC.h>
char auth[] = xxx
char ssid[] = xxx
char pass[] = xxx
Variables
-V4: TRC Open Door Status (From Micro)
-V5: TRC Closed Door Status (From Micro)
-V6: CAM Open Door Status (From Micro)
-V7: CAM Closed Door Status (From Micro)
-V8: Current time
-V9: Current time
-V10: Current time
-V11: Current time
String sthr = "";
String stmin = "";
String stsec = "";
String currentDateTime = "No Data";
int TRCcounter = 0;
int TRCstate = 0;
int TRClaststate = 0;
int CAMcounter = 0;
int CAMstate = 0;
int CAMlaststate = 0;
WidgetRTC rtc;
WidgetLED led14open (V4);  //open
WidgetLED led14close (V5);  //close
WidgetLED led13open (V6);  //open
WidgetLED led13close (V7);  //close
void clockDisplay() {
   if(hour()<10) { sthr="0"+String(hour()); }
   if(hour()>9) { sthr=String(hour()); }
   if(minute()<10) { stmin="0"+String(minute()); }
   if(minute()>9) { stmin=String(minute()); }
   if(second()<10) { stsec="0"+String(second()); }
   if(second()>9) { stsec=String(second());}
   currentDateTime = sthr + ":" + stmin + ":" + stsec;
void TRCdooropen () {
      clockDisplay();
      Blynk.virtualWrite(V9, currentDateTime);
      Blynk.notify("TRC Door is Open");
      led14open.on();
      led14close.off();
void TRCdoorclose () {
      clockDisplay();
      Blynk.virtualWrite(V8, currentDateTime);
      Blynk.notify("TRC Door is Closed");
      led14open.off();
      led14close.on();
void CAMdooropen () {
      clockDisplay();
      Blynk.virtualWrite(V11, currentDateTime);
      Blynk.notify("CAM Door is Open");
      led13open.on();
      led13close.off();
void CAMdoorclose () {
      clockDisplay();
      Blynk.virtualWrite(V10, currentDateTime);
      Blynk.notify("CAM Door is Closed");
      led13open.off();
      led13close.on();
BLYNK_CONNECTED() { rtc.begin(); }
   pinMode(14, INPUT_PULLUP);
   pinMode(13, INPUT_PULLUP);
   Blynk.setProperty(V4,"color","#ff0000");  //red - hex code of RGB value for color
   Blynk.setProperty(V5,"color","#39ff14");  //neon green - hex code of RGB value for color
   Blynk.setProperty(V6,"color","#ff0000");  //red - hex code of RGB value for color
   Blynk.setProperty(V7,"color","#39ff14");  //neon green - hex code of RGB value for color
   setSyncInterval(10 * 60);  //update Node clock chip from server every 10 minutes
}  //end void setup
   if ((digitalRead(14) == HIGH) && (TRCcounter < 50)) { TRCcounter ++; }
   if ((digitalRead(14) == LOW) && (TRCcounter > 0)) { TRCcounter --; }
   if (TRCcounter == 50) { TRCstate = 1; }
   if (TRCcounter == 0) { TRCstate = 0; }
   if (TRCstate != TRClaststate) {
      TRClaststate = TRCstate;
         if (TRCstate == 1) { TRCdooropen (); }
         if (TRCstate == 0) { TRCdoorclose (); }
   }  //end if not equal
   if ((digitalRead(13) == HIGH) && (CAMcounter < 50)) { CAMcounter ++; }
   if ((digitalRead(13) == LOW) && (CAMcounter > 0)) { CAMcounter --;  }
   if (CAMcounter == 50) { CAMstate = 1; }
   if (CAMcounter == 0) { CAMstate = 0; }
   if (CAMstate != CAMlaststate) {
      CAMlaststate = CAMstate;
      if (CAMstate == 1) { CAMdooropen (); }
      if (CAMstate == 0) { CAMdoorclose (); }
}  //end void loop
Here is the Adafruit sample code that worked to read the temp and humidity sensor
  This is an example for the SHT31-D Humidity & Temp Sensor
  Designed specifically to work with the SHT31-D sensor from Adafruit
  ----> https://urldefense.com/v3/__https://www.adafruit.com/products/2857__;!!JhrIYaSK6lFZ!5vm-z6C12EK7OZ2QDCK41nLWtCDafFmdAXAAvGPjjOSdjeiC4x16KluE8Fe40QdVqqw$
  These sensors use I2C to communicate, 2 pins are required to
  interface
#include <Arduino.h>
#include <Wire.h>
#include "Adafruit_SHT31.h"
bool enableHeater = false;
uint8_t loopCnt = 0;
unsigned long tstart = millis();
unsigned long tnow = 0;
Adafruit_SHT31 sht31 = Adafruit_SHT31();
  while (!Serial)
    delay(10);     // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("SHT31 test");
  if (! sht31.begin(0x44)) {   // Set to 0x45 for alternate i2c addr
    Serial.println("Couldn't find SHT31");
    while (1) delay(1);
  Serial.print("Heater Enabled State: ");
  if (sht31.isHeaterEnabled())
    Serial.println("ENABLED");
    Serial.println("DISABLED");
  if ((millis() - tstart) > 1000) {   // Use millis loop instead of delay
  tstart=millis();
  float t = sht31.readTemperature();
  t=(1.8*t)+32;  // convert to *F
  float h = sht31.readHumidity();
  if (! isnan(t)) {   // check if 'is not a number'
    Serial.print("Temp *F = "); Serial.print(t); Serial.print("\t\t");
    Serial.println("Failed to read temperature");
  if (! isnan(h)) {  // check if 'is not a number'
    Serial.print("Hum. % = "); Serial.println(h);
    Serial.println("Failed to read humidity");
  // delay(1000);
  // Toggle heater enabled state every 30 seconds
  // An ~3.0 degC temperature increase can be noted when heater is enabled
  if (++loopCnt == 30) {
    enableHeater = !enableHeater;
    sht31.heater(enableHeater);
    loopCnt = 0;
And here is the merged program that doesn’t work.
// Set Board to Node MCU 1.0 in Tools
// To upload program:  Need to connect Pin D3 (Flash / GPIO0) to GND. Disconnect after upload.
// following includes are for SHT31 temp sensor
#include <Wire.h>
char auth[] = xxx
char ssid[] = xxx
char pass[] = xxx
Variables Used:
-V8: Current time TRC closed
-V9: Current time TRC open
-V10: Current time CAM closed
-V11: Current time CAM open
-V12: SHT31 Temperature
-V13: SHT31 Relative Humidity
String sthr = "";
String stmin = "";
String stsec = "";
int TRCcounter = 0;
int TRCstate = 0;
int CAMcounter = 0;
int CAMstate = 0;
// following declarations are for SHT31
bool enableHeater = false;  //heater used to eliminate condensation
WidgetRTC rtc;
WidgetLED led14open (V4);  // open LED TRC
WidgetLED led14close (V5);  // close LED TRC
WidgetLED led13open (V6);  // open LED CAM
WidgetLED led13close (V7);  // close LED CAM
      clockDisplay();
      led14open.on();
      led14close.off();
      clockDisplay();
      led14open.off();
      led14close.on();
      clockDisplay();
      led13open.on();
      led13close.off();
      clockDisplay();
      led13open.off();
      led13close.on();
// NEED FOLLOWING???
   while (!Serial)
   pinMode(14, INPUT_PULLUP);  // TRC door - pin D5 / GPIO14
   pinMode(13, INPUT_PULLUP);  // CAM door - pin D7 / GPIO13
// Following for SHT31
     while (1) delay(1);
}  //end void setup
   }  // end if not equal
// following is for SHT31
   if ((millis() - tstart) > 2000) {   // Use millis loop instead of delay
   tstart =  millis();
     float t = sht31.readTemperature();  // disconnects Blynk!
     t = (1.8 * t) + 32;  // convert temperature to *F
     float h = sht31.readHumidity();  // disconnects Blynk!
     Blynk.virtualWrite(V12, t);
     Blynk.virtualWrite(V13, h);
// A ~3.0 degC temperature increase can be noted when heater is enabled
   loopCnt = 0;
   }  // end if millis()
}  // end void loop
Sorry about the mess of code. If anyone can tell me how to better format the text, I’d appreciate it.
@macardoso please edit your posts, using the pencil icon at the bottom of each one, and add triple backticks at the beginning and end of your code so that it displays correctly.
Thanks Pete! I tried a few code block tags but couldn’t figure out how to get it to render correctly. That looks much better :slight_smile:
You should start by reading this:
Then restructure your code so that you get rid of all the delays and millis comparisons and use BlynkTimers instead.
In the combined code, the SHT31 initialisation is commented-out in void setup. Why is this?
Pete,
Thanks again for the response. Unsure why the SHT31.begin is commented out, I will make sure it is added back into the program.
We will work on restructuring the code and see if that helps. EDIT: we need debounce so HW interrupts are not usable - removed previous question.
You can denounce hardware interrupts, but it’s probably easier to have a timed routine that polls the contact states at say 100ms intervals. No normal contact bounce is going to last that long, so it in effect auto debounces the contacts.
Well, guess what… it works!
The culprit was the commented out section of sht31.begin().
I’m guessing that if the temperature is read without the communications being started, it hangs waiting for a timeout. This starves the blynk.run(). Fixing just that got everything working.
We are going to restructure the code anyways to make it cleaner. Thanks for the help!
