So first off the software app is awesome! That out of the way I do PLC programming and I’m new to C+ and Arduino. All I’m looking to do is pulse the Arduino output with a button press from my Android phone. I found the Button Interrupt example code works how I need it to. Push a button and the output pin pulses. What I’m having trouble with is getting the code right to add a second button.
So two questions:
1: Is there a simpler way to have the app button pulse the output pin with a press?
2: What would help is someone to modify the below code for one button and one output to have a 2nd button and output. I can look at the changes and see what the difference is and where. I learn best that way and can modify it from there.
Thank You
: Arduino UNO with Ethernet Shield
http://twitter.com/blynk_app
This example shows how to monitor a button state
using interrupts mechanism.
App project setup:
LED widget on V1
#include <Ethernet.h>
char auth[] = "MyTokenHere";
#define W5100_CS 10
#define SDCARD_CS 4
WidgetLED led1(V1);
// We make these values volatile, as they are used in interrupt context
volatile bool pinChanged = false;
volatile int pinValue = 0;
// Most boards won't send data to WiFi out of interrupt handler.
// We just store the value and process it in the main loop.
void checkPin()
// Invert state, since button is "Active LOW"
pinValue = !digitalRead(2);
// Mark pin value changed
pinChanged = true;
pinMode(SDCARD_CS, OUTPUT);
digitalWrite(SDCARD_CS, HIGH); // Deselect the SD card
Blynk.begin(auth);
//Blynk.begin(auth, "blynk-cloud.com", 80);
//Blynk.begin(auth, IPAddress(192,168,1,100), 8080);
// Make pin 2 HIGH by default
pinMode(2, INPUT_PULLUP);
// Attach INT to our handler
attachInterrupt(digitalPinToInterrupt(2), checkPin, CHANGE);
if (pinChanged) {
// Process the value
if (pinValue) {
led1.on();
led1.off();
// Clear the mark, as we have processed the value
pinChanged = false;
