Hi, I’m brand new to all of this and I’m not exactly sure what I’m doing. I’m looking to receive analog data from a Sparkfun Pro Micro 3.3v through an HC-05 bluetooth module onto my phone. The data being received is from the Sparkfun AD8232 Single Lead Heart Rate Monitor. When looking at the example code for this, it seems to be writing about virtual pins, however I am trying to get analog data so I’m not sure how that applies.
The original code I used for the arduino alongside processing was as follows:
// initialize the serial communication:
pinMode(10, INPUT); // Setup for leads off detection LO +
pinMode(11, INPUT); // Setup for leads off detection LO -
if((digitalRead(10) == 1)||(digitalRead(11) == 1)){
Serial.println('!');
else{
// send the value of analog input 0:
Serial.println(analogRead(A0));
//Wait for a bit to keep serial data from saturating
delay(1);
This code worked when connecting to the computer through USB and using a processing interface to see a graph. How should I alter the example code given for the Pro Micro with an HC-05 in order to get it to do what I want? Any help would be greatly appreciated. The end goal of using blynk is to have a graph on the phone display the analog data being received.
