Hi blynkers!
I’m trying to use the numeric input, but I not sure what I’m doing wrong
#include <IRremoteESP8266.h>
#include <ESP8266mDNS.h>
#include <WiFiUdp.h>
#include <ArduinoOTA.h>
char auth[] = "";
char ssid[] = "";
char pass[] = "";
int arcond = 0;
IRsend irsend(14);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
digitalWrite(4, 0);
digitalWrite(5, 0);
irsend.begin();
ArduinoOTA.setHostname("Sanca");
Serial.println("Booting");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, pass);
while (WiFi.waitForConnectResult() != WL_CONNECTED) {
Serial.println("Connection Failed! Rebooting...");
delay(5000);
ESP.restart();
ArduinoOTA.onStart([]() {
String type;
if (ArduinoOTA.getCommand() == U_FLASH)
type = "sketch";
else // U_SPIFFS
type = "filesystem";
// NOTE: if updating SPIFFS this would be the place to unmount SPIFFS using SPIFFS.end()
Serial.println("Start updating " + type);
ArduinoOTA.onEnd([]() {
Serial.println("\nEnd");
ArduinoOTA.onProgress([](unsigned int progress, unsigned int total) {
Serial.printf("Progress: %u%%\r", (progress / (total / 100)));
ArduinoOTA.onError([](ota_error_t error) {
Serial.printf("Error[%u]: ", error);
if (error == OTA_AUTH_ERROR) Serial.println("Auth Failed");
else if (error == OTA_BEGIN_ERROR) Serial.println("Begin Failed");
else if (error == OTA_CONNECT_ERROR) Serial.println("Connect Failed");
else if (error == OTA_RECEIVE_ERROR) Serial.println("Receive Failed");
else if (error == OTA_END_ERROR) Serial.println("End Failed");
ArduinoOTA.begin();
Serial.println("Ready");
Serial.print("IP address: ");
// 18°
unsigned int LD[119] = {8440, 4196, 616, 1608, 640, 484, 612, 512, 592, 508, 640, 1608, 616, 480, 620, 508, 616, 508, 588, 1636, 612, 1608, 644, 484, 588, 536, 616, 508, 588, 536, 540, 584, 588, 512, 592, 532, 588, 540, 584, 512, 588, 540, 560, 560, 536, 1688, 560, 568, 560, 1660, 540, 612, 536, 564, 532, 592, 536, 1688, 536, 62268, 8448, 4160, 624, 1628, 596, 528, 600, 500, 620, 504, 596, 1624, 624, 504, 596, 528, 596, 504, 624, 496, 600, 528, 600, 496, 624, 504, 600, 524, 596, 504, 624, 500, 596, 528, 600, 500, 624, 500, 600, 1620, 628, 1620, 600, 504, 624, 1624, 600, 496, 624, 504, 600, 524, 596, 1628, 596, 1628, 620, 1628, 596}; //COLE A LINHA RAW CORRESPONDENTE DENTRO DAS CHAVES
// 20
unsigned int MT[125] = {3904, 360, 1444, 880, 300, 724, 220, 4824, 508, 1740, 484, 668, 460, 668, 480, 648, 396, 1772, 532, 620, 476, 620, 480, 672, 428, 1740, 484, 1740, 560, 720, 380, 588, 508, 596, 500, 620, 508, 724, 400, 648, 480, 696, 372, 644, 508, 724, 424, 752, 352, 668, 376, 1824, 424, 780, 400, 1688, 484, 644, 504, 620, 508, 696, 372, 1772, 480, 62976, 8416, 4188, 624, 1628, 596, 504, 624, 500, 596, 528, 596, 1628, 596, 532, 592, 504, 624, 496, 600, 528, 600, 496, 624, 504, 592, 532, 596, 504, 620, 504, 596, 528, 596, 500, 624, 504, 596, 1624, 624, 504, 596, 1628, 624, 500, 596, 1624, 624, 504, 592, 536, 592, 1628, 596, 528, 596, 504, 620, 1628, 596}; //COLE A LINHA RAW CORRESPONDENTE DENTRO DAS CHAVES
// 22°
unsigned int PP[119] = {8448, 4160, 624, 1628, 596, 500, 624, 504, 596, 524, 600, 1624, 600, 524, 596, 504, 624, 500, 596, 1628, 624, 1624, 600, 504, 620, 500, 600, 528, 592, 504, 624, 500, 596, 528, 600, 500, 624, 500, 600, 524, 600, 500, 624, 500, 600, 1624, 624, 500, 600, 1624, 624, 504, 596, 524, 600, 496, 628, 1624, 596, 41976, 8424, 4188, 624, 1624, 600, 496, 624, 504, 600, 524, 596, 1628, 596, 528, 600, 500, 624, 500, 600, 524, 596, 504, 620, 504, 596, 532, 592, 504, 624, 500, 596, 528, 600, 500, 624, 500, 600, 1620, 624, 1628, 596, 1628, 596, 528, 600, 1620, 600, 528, 596, 504, 620, 1624, 600, 504, 624, 1624, 600, 1624, 600}; //COLE A LINHA RAW CORRESPONDENTE DENTRO DAS CHAVES
// 24°
unsigned int VV[60] = {8400, 4200, 600, 1550, 600, 500, 550, 500, 600, 500, 550, 1550, 600, 500, 550, 500, 600, 500, 550, 500, 600, 500, 550, 500, 600, 500, 550, 500, 600, 500, 550, 500, 600, 500, 550, 1550, 600, 500, 600, 500, 550, 1550, 600, 500, 600, 1550, 600, 500, 600, 1550, 600, 1550, 600, 1550, 600, 1550, 600, 500, 550};
// 26°
unsigned int MM[60] = {8400, 4200, 600, 1550, 600, 500, 600, 500, 600, 500, 600, 1550, 600, 500, 600, 500, 600, 500, 600, 500, 600, 500, 600, 500, 600, 500, 600, 500, 600, 500, 600, 500, 600, 500, 600, 1550, 600, 500, 600, 1550, 600, 1550, 600, 500, 600, 1550, 600, 500, 600, 1550, 600, 500, 600, 500, 600, 500, 600, 500, 600};
// Of
unsigned int VT[59] = {8448, 4192, 592, 1624, 628, 500, 600, 528, 592, 504, 632, 1616, 600, 504, 620, 500, 600, 528, 592, 1628, 596, 1628, 624, 500, 600, 528, 596, 500, 624, 500, 596, 532, 596, 500, 624, 504, 596, 524, 600, 500, 624, 500, 600, 528, 596, 1628, 596, 524, 600, 1624, 600, 528, 596, 500, 624, 504, 596, 1624, 628}; //COLE A LINHA RAW CORRESPONDENTE DENTRO DAS CHAVES
BLYNK_WRITE(V4) {
switch (param.asInt())
case 1: // Item 1
irsend.sendRaw(LD,119,32); // PARÂMETROS NECESSÁRIOS PARA ENVIO DO SINAL IR
Blynk.setProperty(V4, "color", "#04C0F8");
break;
case 2: // Item 2
irsend.sendRaw(MT,125,32); // PARÂMETROS NECESSÁRIOS PARA ENVIO DO SINAL IR
break;
case 3: // Item 3
irsend.sendRaw(PP,119,32); // PARÂMETROS NECESSÁRIOS PARA ENVIO DO SINAL IR
break;
case 4: // Item 4
irsend.sendRaw(VV,60,28); // PARÂMETROS NECESSÁRIOS PARA ENVIO DO SINAL IR
break;
case 5: // Item 5
irsend.sendRaw(MM,60,28); // PARÂMETROS NECESSÁRIOS PARA ENVIO DO SINAL IR
break;
case 6: // Item 5
irsend.sendRaw(VT,59,32); // PARÂMETROS NECESSÁRIOS PARA ENVIO DO SINAL IR
Blynk.setProperty(V4, "color", "#D3435C");
break;
default:
Serial.println("Unknown item selected");
BLYNK_WRITE(V3){
if(arcond == 0 && V2 == 18){
Blynk.virtualWrite(V4, 18);
arcond = param.asInt();
ArduinoOTA.handle();
The numeric input is on V2 and I’m trying to use it with a button on V3
