im having problem display the output on serial monitor cant figure out why
#define BLYNK_TEMPLATE_ID "TMPLEMJi8XeT"
#define BLYNK_DEVICE_NAME "Quickstart Device"
#define BLYNK_AUTH_TOKEN "q0o0UDBNYuX2ttDvGYgxNerDzeUe91Rg"
#include <OneWire.h>
// Replace YOUR_AUTH_TOKEN with your Blynk auth token
char auth[] = "q0o0UDBNYuX2ttDvGYgxNerDzeUe91Rg";
// Replace your_ssid and your_password with your WiFi credentials
char ssid[] = "bb";
char pass[] = "amirizzani12";
// Data wire is connected to D3 on the Wemos D1 Mini
#define ONE_WIRE_BUS D3
// Setup a oneWire instance to communicate with any OneWire devices
// Pass our oneWire reference to Dallas Temperature.
// Define a Blynk timer
// This function will be called every time the timer expires
void sendTemperature()
// Request a temperature reading from the DS18B20
// Get the temperature from the DS18B20
float temperature = sensors.getTempCByIndex(0);
// Send the temperature to Blynk via virtual pin V1
Blynk.virtualWrite(V1, temperature);
// Initialize the serial port
// Connect to WiFi
WiFi.begin(ssid, pass);
delay(500);
Serial.print(".");
// Connect to Blynk
// Initialize the DallasTemperature library
sensors.begin();
// Set the timer to send a temperature reading every 60 seconds
timer.setInterval(60000, sendTemperature);
// Run the Blynk timer
only dotted line is displayed output on serial monitor
